Another head to port & polish 94AB
Page 1 of 2 [ 20 posts ] Go to page 1, 2  Next
 Post subject: Another head to port & polish 94AB
Posted: Wed Oct 31, 2007 10:37 pm
Ride: 93 ED sedan
Power: 161 rwkw
Well, now that my previous head is my car now, I gotta do another head. This one is an EF unit, 94AB, had it sitting out on the veranda for a couple of years, so now its up for a bit of work for my new engine. I'm just about to start.
The funny thing is, the hole in the genuine exhaust manifold gasket, is the same size as the head on the ex valve.
http://youtu.be/jJTh9F3Vgg0
Posted: Wed Oct 31, 2007 11:02 pm
On that other head you put on your car, what is the thing under where the valves are. The j shaped thingy, and how come this head doesn't have one ? Is that the 'swirl chamber' I have heard people talk about ?
Sorry for my lack of technical words. :)
Looks like you have a lot of fun hours ahead of you. :P Good luck.
Posted: Wed Oct 31, 2007 11:07 pm
Ride: 93 ED sedan
Power: 161 rwkw
The first head is off an EA. Only the 3.9's had that. Was deleted with the intro of the 4.0's. It isn't really a "swirl chamber", more of a guide to produce a swirl.
Posted: Fri Nov 02, 2007 9:49 pm
Ride: 93 ED sedan
Power: 161 rwkw
I have just finished polishing one combustion chamber. Took about 2 hrs.
Posted: Fri Nov 02, 2007 10:44 pm
what do u use to polish the chamber ?
Posted: Fri Nov 02, 2007 10:47 pm
Ride: 93 ED sedan
Power: 161 rwkw
I used a Dremel.
Posted: Fri Nov 02, 2007 10:56 pm
Ride: el falcon
Power: 608 rwkw
y didn't u lay bak the chamber around the valves on the opposite side to spark plug? gains to be had there
# 1997 EL Falcon GLI - 600+rwkw
# 2008 FPV FG GTE - Xa Coilovers, 20x8/ 20x10 Fairladys
Posted: Fri Nov 02, 2007 11:04 pm
Ride: 93 ED sedan
Power: 161 rwkw
Not doing it for turbo, N/A, Hypereutectic raised pistons going in. Looking at 10:1 to 10.5:1 comp. ratio.
Posted: Sat Nov 03, 2007 12:23 am
Ride: ef xr8
Power: 229 rwkw
The head is going to be shaved as well?
Looks good so far, It'll be interesting to see what it'll do.
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Sat Nov 03, 2007 12:24 pm
again why didn't you lay back chamber around the valves? if you are using domed pistons the 2 or 3cc gain in chamber size wouldn't matter anyway.
but the flow gain would be well worth it.
seems like alot of time and effort for a gain or 3/8th of f**k all
Posted: Sat Nov 03, 2007 3:55 pm
So looking at those pics the intake valve looks like it goes up pretty close to the surface of the head, so how much can you shave off before having issues? hard to see exactly from the pics just how much room there is.
Also the valves look like they are concaved... does anyone make valves with a flat bottom to them for a bit less overall CC volume? Unless there is a proper reason they need to be concaved in like that?
Posted: Sat Nov 03, 2007 7:48 pm
Gallery: 28 images
Ride: EF Fairmont Station Wagon.
Power: 150 rwkw
I think tickford_6 is talking about something like this.
4.0L EF Fairmont Station Wagon. EL GT Snorkel. K&N Pod in air box. 3" Intake piping.
Home port job. 1636 Wade cam. Wildcat Extractors, 2 1/2" cat and exhaust.
2200/2400rpm Dominator More Stall. Stage two mechanical shift kit. 3.73 4 pinion LSD. 15.078 @ 92mph.
Posted: Sat Nov 03, 2007 7:56 pm
Ride: 2007
Can you explain more (perhaps with an arrow)I am thinking of a DIY head polish and need as much info as I can get.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Sat Nov 03, 2007 11:04 pm
bang on the money
Posted: Sat Dec 01, 2007 9:28 pm
Ride: 93 ED sedan
Power: 161 rwkw
I finally got back to it this arvo. I have done the exhaust port now. I have made it the same size as the genuine exhaust gasket as seen in the pic.
Users browsing this forum: No registered users and 83 guests
It is currently Sun Jun 08, 2025 3:28 am All times are UTC + 11 hours
