Chugging car
Page 1 of 2 [ 28 posts ] Go to page 1, 2  Next
 Post subject: Chugging car
Posted: Fri Jul 24, 2009 10:12 am
Ride: Falcon AU
My stock AU Forte has recently been "chugging" while the car is idle at for example a traffic light.
I'm not sure if it's the cold weather in perth or something else.
It happens randomly, usually when the temperature has not yet reached normal operating temperature. i.e. towards the cold side.
Sitting in the driver's seat it feels like small jerks pushing you forward.
Is this "chugging" completely normal? The car is 10 years old now.
It is also duel fuel LPG/petrol
What do you call a Hyundai with dual exhausts?
A wheelbarrow.
 Post subject: Re: Chugging car
Posted: Fri Jul 24, 2009 12:19 pm
Ride: SF5 Forester
service? fuel filter
R.I.P Tobias my son.
Posted: Fri Jul 24, 2009 7:54 pm
Ride: Falcon AU
Oh could it be a fuel filter issue?
That might be it.
How does the fuel filter cause the "chugging"?
A wheelbarrow.
Posted: Fri Jul 24, 2009 11:35 pm
Ride: BF F6 Tornado - #0077
intake gasket hasnt gone? think the one in my has gone. $50 for gaskets, $50 for piss, a lot of swearing and good times for me in the not too distant future
** For Sale ** {DESCRIPTION}
F6 Tornado 2006 {DESCRIPTION}
No?
Then f**k off
Posted: Fri Jul 24, 2009 11:48 pm
Ride: Falcon AU
How do I know if the gasket is gone?
Will the car still run with the gasket gone?
A wheelbarrow.
Posted: Sat Jul 25, 2009 4:19 pm
car will still run. The intake runners mate to the cylinder head, that gasket. Its a PITA job getting the lower bolts out.
You can test by getting a length of hose and running it along, you might hear a sucking noise in it. the other is an unlit butane touch. run it along the gasket, the vacuum in the manifold will suck the butane (or other hydrocarbons, wd40, rp7 etc) and the engine will run bad (worse)
No?
Then f**k off
Posted: Sat Jul 25, 2009 6:30 pm
Ride: 1993 ED Fairmont
Intake gaskets are easy to replace :) maybe you like drinking and swearing while you work :)
Posted: Tue Jul 28, 2009 10:58 pm
Ride: Falcon AU
I've been monitoring this "chugging" problem very closely as I drive recently, and noticed the following:
When I drove the car slowly today at about 10-60kms per hour the chugging happens... this is on LPG
However once I step on the accelerator to about 80-100kms per hour for say 5 minutes, the chugging dissapears.....!
Once I slow back down to 10-60kms for about 2 mins, the chugging comes back again....
Does this help figure out what it could be?
Fuel filter or Head Gasket, or something else?
A wheelbarrow.
Posted: Wed Jul 29, 2009 10:59 am
Ride: AUII XR6, EBII XR6
Plugs maybe? a mate's colt used to do a similar thing before we changed the plugs...
EBII S XR6: 5 Speed short shifter, 4499s, gutted cat, 2.5" Redback, K&N Pod.
AUII XR6: 5 speed, King Super Low Rears.
Posted: Wed Jul 29, 2009 7:51 pm
Ride: Falcon AU
I did a run on the car today.
It's a duel fuel car..
On LPG the "chugging" is very evident.
On Petrol, the "chugging" is still there but less so.
I've got genuine spark plugs (recommended by Ford) in it.
A wheelbarrow.
Posted: Tue Aug 04, 2009 8:33 pm
Ride: Falcon AU
Hi all,
I've been monitoring this problem for about 2 weeks now
I've changed the spark plugs and the fuel filter.
It's still chugging!
But.... I discovered something new. While the car engine was running but the car is idle, I walked to the back of the car and noticed the exhaust making some weird noise.
It's almost like the exhaust is "Coughing"
What do you guys reckon? I need a new exhaust??
A wheelbarrow.
Posted: Tue Aug 04, 2009 8:54 pm
Ride: AU fairmont ghia
what about your cat? wouldnt chugging might mean your cat could be bad
AU FAIRMONT GHIA: 5.0 Dealer ordered SVO mods ( seeking clarification ATM), tickford suspension.
Posted: Tue Aug 04, 2009 9:24 pm
Ride: Falcon AU
what's the worst case scenario... if i leave the car chugging on like this with a bad cat, what could happen?
A wheelbarrow.
Posted: Tue Aug 04, 2009 9:36 pm
Ride: ED Pwnage Pwr!!
Like others have said mate, its probably the intake gasket.
Dads EF on gas had this problem and we change the gasket, twas much better after!
Also, have you had any backfires through the airbox on LPG?
{DESCRIPTION} < Click on it! You know you want too!
ED HP AU XR6, Wade, T5, and all the usual stuff!
Quote:
Thats not the point *a**hole
Posted: Tue Aug 04, 2009 9:41 pm
Ride: Falcon AU
how do i tell if it backfired?
A wheelbarrow.
Users browsing this forum: No registered users and 63 guests
It is currently Fri Jun 06, 2025 12:46 pm All times are UTC + 11 hours
