jvangent |
yesterday the while driving normaly dropping my little bro to work my engine started to make a ticking noise, so i pulled over to check, checked oil pressure everything ok there! went back home and ripped the rockercover off everything seems to be ok. ran it again and it seemed to stop. so this morning i drove to work testing the engine changing from 1st to 2nd and 3rd at 50km/h seemed ok. then suddenly it started again! i have the day off 2morrow to look closer. does anyone know what may be wrong????
jvangent |
oh and to add some more info i have noticed a reduced amount of power as well.
MickEBS |
How long since last oil and filter change? Did you use guage on dash to check oil pressure? Problem sounds like it only happens when engine is hot.
jvangent |
na it happens when the engine is cold too.... i changed the oil about 200km ago so its pretty new. yeah i just used the dash to see if oil pressure was there, when i took the rockercover off there eas heaps of oil there still. so dont know.... at first i thought oil pressure was gone, but i dont think that is it. i may be wrong ill have to open her up again 2morrow.
B0XCAR |
a stuffed lifter?
jvangent |
hmmmmmm it could be..... ill check that 2morrow.
bushman |
sounds like it could also be a spun big end bearing, do you flog it alot ? rev limiter style ?
how many k's?
_________________ THE LOOSEST MUTHA FUKA YOU'VE EVER MET |
jvangent |
{USERNAME} wrote: sounds like it could also be a spun big end bearing, do you flog it alot ? rev limiter style ? how many k's? lol na i hardly get it above 4grand its done 200xxxk's..... thinking this may be a good time to get another engine and do a whole re-build. |
MickEBS |
I've got a EB spack 5 speed that has done nearly 340k on original motor with only the head done bout 180k ago. Runs happily on lpg over the 4 grand mark quite regularly and without any lifter noise. Only lifter noise I get is on first startup in the mornings and that is minor. The motor in the falcons are pretty solid and at only 200k and if other wise running well, might be worth fixing what you got. Unless of course during the course of the rebuild you want to put some go faster bits in! In that case go for the build and have some fun with it.
jvangent |
{USERNAME} wrote: I've got a EB spack 5 speed that has done nearly 340k on original motor with only the head done bout 180k ago. Runs happily on lpg over the 4 grand mark quite regularly and without any lifter noise. Only lifter noise I get is on first startup in the mornings and that is minor. The motor in the falcons are pretty solid and at only 200k and if other wise running well, might be worth fixing what you got. Unless of course during the course of the rebuild you want to put some go faster bits in! In that case go for the build and have some fun with it. hey thanks mate, yeah was thinking about getting some more horses out of her with a re-build. but i dont know where ill go from here yet. |
Users browsing this forum: Google [Bot] and 35 guests |
