Power Steering Fluid
Page 1 of 1 [ 9 posts ]
 Post subject: Power Steering Fluid
Posted: Fri Nov 06, 2009 8:14 pm
Ride: AU Mont 2000
Just curious, what kind of power steering fluid do you guys use?
I've got an AUII 2k Fairmont and I called Coventrys who offered me Motorcraft brand Power Steering Fluid with stock code R1424 for $15 per litre
What do you guys recommend?
I dont mind so much the cost, I just want the best stuff to preserve and lubricate the steering column
 Post subject: Re: Power Steering Fluid
Posted: Fri Nov 06, 2009 8:35 pm
Ride: 93 ED sedan
Power: 161 rwkw
That is what I use, ( in the EA and the ED ) even use it in the missuses '01 Magna Solara 3.5...... R1-424.
http://youtu.be/jJTh9F3Vgg0
Posted: Fri Nov 06, 2009 9:03 pm
R1 424 is used for EF-FG. Ford lists R1 36 Auto fluid for EA-ED.
Posted: Fri Nov 06, 2009 9:51 pm
Ride: 93 ED sedan
Power: 161 rwkw
Series 1 of the EF's left the factory with Dex II/III ( R1-36 ) fluid for power steer fliud.
The EF's were turning that fluid black by 80,000km, and the racks were "squeaking".
So we changed the fluid to the R1-424 and in about 1,000km, the squeak was gone.
The series 2 EF's came with the new fluid.
At that time we were supplied with 4 litre bottles of Mobil 424 Tractor Tranmission Fliud to use before Ford had their own bottles of the stuff.
I was working on these cars when they were new at a Ford dealership. I was registered Ford Technician.
I does not hurt to run the R1-424 in earlyier Falcons. I even used it in the power steering of an XD V8 sedan. Been in there now for just over 5 yrs.
Posted: Fri Nov 06, 2009 10:09 pm
Ride: AU Mont 2000
So you recommend the R1424 for the AU Fairmont?
Posted: Fri Nov 06, 2009 10:11 pm
Ride: 93 ED sedan
Power: 161 rwkw
They left the factory with it in there, so, yes.
Posted: Fri Nov 06, 2009 10:24 pm
Ride: AU Mont 2000
you just said they left the factory with R1-36, scroll up
Posted: Fri Nov 06, 2009 10:34 pm
Ride: 1993 EB XR8
read it again he said EF1 and it changed for EF2
Posted: Fri Nov 06, 2009 10:43 pm
Ride: AU Mont 2000
cheers thanks for the advice i'll stick with R1424
Users browsing this forum: No registered users and 82 guests
It is currently Sat Jun 07, 2025 7:06 pm All times are UTC + 11 hours
