newxr |
Hi
Engine bay heat in the BA is a real problem IMO ![]()
_________________ <b>XR6NA with T Snorkal in Silhouette with Lux Pack + 2nd CAI XR8 Snorkel, Pacemaker Headers, High Flow Cat, Redback Exhaust with Twin Tailpipes - 149kw (G-Tech)</b>, Lower Grill, Side Air Bags, Power Pedals, Boot Lid Carpet, Boot Liner, Rear Sun Screen, Mats, Spats, Scuffs, Tint, Gold Plated Badges |
Disco Frank |
mm all u can do is maybe get som ef/el style bonnet scoops to remove the hot air..
or get the exhaust heat wraped or HPC coated. also above the firewall between the bonnet there is a rubber sealing strip .. remove this as it allows airflow through the engine bay ![]() you can even go to the extremes of adding some washers to thebonnet hinges so there is a bigger gap at the back of the bonnet
_________________ RIP SCOTT |
Slick |
{USERNAME} wrote: Hi
Engine bay heat in the BA is a real problem IMO ![]() Is it a new car? still in the run-in period? As I recall, the engine runs hot during run in. probably due to a higher friction rate til it settle into the right tolerance. use higher octane fuel during that time, stay away frrom regular u/l petrol otherwise she'll be running to much timing advance=heat feel free to correct me if I'm wrong.
Users browsing this forum: No registered users and 40 guests |
