effalconxr6 |
when i changed my ignition leads on my ef it started to missfire every time after ive been giving it sum. is it true that in order to stop this i need genuine ford leads?
_________________ EF XR6, Red in colour, T5 with short shift, tired LSD, Pioneer head unit, 2.5 exhaust with staino pacemakers, 68mm TB, dumped on ultras, sitting on FTR's with EL bodykits |
SV-Valiant |
{USERNAME} wrote: when i changed my ignition leads on my ef it started to missfire every time after ive been giving it sum. is it true that in order to stop this i need genuine ford leads? Nope i think the only time mine had original leads on it was probably when it came out of the factory. Check you have them on properly and check that they or one of them isnt shorting out. |
ELboy |
there are alot better leads on the market then what ford will sell you, it will have nothing at all to do with the brand you have used if they are the rite leads for your car. Obviously you have mixed a lead up somewhere, if the leads don't have numbers on them number them so you don't mix them up, also make sure they are on properly if you hear a click there on properly
EF-MattyB |
It may also be worth checking you coil pack, as my old EF had similar problems under load (it would miss and f@rt).
_________________ 99 AU Fairlane Ghia V8 Black Leather, 19" ANZ 5+5's with 245/35 rubber |
efxr6wagon |
If it only started when you changed the leads, they might not be properly attached to the coil or spark plugs. It's a devil of a job getting them to attach securely to the coilpack especially. You should hear or feel a definite 'click' when it hooks up.
_________________ 95 EF XR6 wagon, 17" FTRs, DBA rotors, KYB/Koni, AU bottom end, ported EF head, backcut valves, SS Inductions, Territory intake, 10.2 CR, Auckland 1258 cam, vernier gear, PH4480 headers, no cat, Tickford 2.5", 2800rpm stall, J3 chip |
effalconxr6 |
the leads are numbered and in the correct order. as i said before it only starts missfiring after a flogging, other wise the car runs fine so the leads are on properly. im starting to think that it could be the coil pack now????
Users browsing this forum: No registered users and 50 guests |
