Shifteh |
I really want a more lumpy cam in my ef, somethin that will sound like this one
http://www.youtube.com/watch?v=QrqN-BIumSk ANy idea's??
_________________ Crank Assembly balanced, HV oil pump, ACL Trimetal bearings, "1 extra oil clearance taking to around 0.0650-0.0700 on mains and big ends, Moly rings,, Xr6 Cam, POD ( Possibly oversize injectors), Block, Head, Timing cover, belt idler, Alternator,painted in ford light blue |
Shifteh |
have any of you guys played around with cams i really want something that will go on a stock ef engine thats "lumpy" so it sounds like Blop Blop Blop Blop kinda thing , kinda want it to idle too lol
BenJ |
Hi.
Unfortunately, what you want doesn't really exist. On a stock engine with no headwork, fuel upgrades or ECU alterations, there are only a couple of cams that will increase performance and still make it actually useable on a daily basis. Also, is your car auto or manual, as an Auto car has even less options. I have a Wade 1673 cam which works great with a manual transmission. However, this cam is considered too large for use behind an automatic. At idle it has a slight lope which I find sounds good to my ear. My car has intake and exhaust improvements, but the head and block are stock. I do have the XR6 300kpa fuel pressure regulator, and the Tickford EL Ghia ECU. So while my 'engine' is stock, the rest has been modified to allow the cam to work to it's best. I can go one step further and have a J3 chip installed with a modified tune to suit the cam, and I also have a Tickford head to go on at some point. If your car is an auto, the Wade 1636 would be my suggestion, and no, it will not sound lumpy, but it will not stall all the time, and will have good low end and mid range improvements. Cheers BenJ
Shifteh |
Cheers, its an auto, and look at my garage then ull see what i mean ,
itlookslikeaxr6 |
his car prob sounds like that because the ECU isn't use to the new cam and is trying to learn
paulos |
buy a tractor
nah the vid says on there that its untuned which is why it sounds like that, when its tuned it would be diffrent ( less lumpy) but more useable
_________________ God made s**t, Holden put wheels on it |
bradley4567 |
{USERNAME} wrote: I really want a more lumpy cam in my ef, somethin that will sound like this one http://www.youtube.com/watch?v=QrqN-BIumSk ANy idea's?? sounds like my pocket rocket with no exhaust on it
_________________ ef falcon daily driver |
Shifteh |
fk i just have to keep listening to that sounds so Fking DAM GOOD!
bradley4567 |
{USERNAME} wrote: buy a tractor
