Injector use's ???? Gas????
Page 1 of 1 [ 11 posts ]
 Post subject: Injector use's ???? Gas????
Posted: Wed Mar 31, 2010 2:38 am
Ride: Ford EF - Garret TO4Z
hi im thinking of using an injector as a gas valve,, nothing to do with car all togather?
basically making system to run oxy/hyd torch
any thorghts was thinking i maby could use one as a varable gas valve maby for the torch???
any idea?
Crank Assembly balanced, HV oil pump, ACL Trimetal bearings, "1 extra oil clearance taking to around 0.0650-0.0700 on mains and big ends, Moly rings,, Xr6 Cam, POD ( Possibly oversize injectors), Block, Head, Timing cover, belt idler, Alternator,painted in ford light blue
 Post subject: Re: Injector use's ???? Gas????
Posted: Wed Mar 31, 2010 10:10 am
Ride: BA Futura
Depends on the required throughput, and what pressures the gas would be at.
Another consideration is the seal on the injector.. you wouldn't want a small leakage or anything of that sort, it could prove disastrous..
And you would also want to ensure that any non-sealed electrics operating the injector (power, switches, etc) don't ever create a spark or aren't insulated properly and contact other power systems or metal surfaces.. Carelessness here would be dangerous if there was a small leak and a spark..
Just buy a simple pressure regulator or variable regulator with a stop valve. It would also have tested and up-to-standard specification seals and fittings, and would also have the commonly used fittings which would make connections easier too.
DCII LTD V8 - leather - low k's
1978 XC '1/2' 500 project 302C
BA Futura wagon
P38 Range Rover HSE
Posted: Wed Mar 31, 2010 10:43 am
, what i was thinking , the gas would be at like a low pressure like 5-10 psi, will this go through the injector or do injectors require a larger pressure behind them along with them to be on???
Posted: Wed Mar 31, 2010 10:59 am
Ride: BA Futura
I'm not sure on the operating specifications of the standard injectors..
E-series XR's have ~300KPA fuel pressure, which is about 43.5 PSI.
Another consideration is temperature, gas might freeze or cool the injector to below operating temperature tolerances. You'd also want to check is gas would give adequate lubrication to the injector, they are designed to rely on petrol for lubrication.
Have a hunt around the internet for aftermarket injector specifications, also have a look into what injection type gas systems use for the injection.
I still think it would be a low easier, safer, more piratical and cheaper to just use a gas fitting which is specially designed for such applications..
BA Futura wagon
P38 Range Rover HSE
Posted: Wed Mar 31, 2010 11:07 am
yeah i know but how cool would a tourch with a trimpot on it to control the valve be
Posted: Wed Mar 31, 2010 11:19 am
Ride: BA Futura
Not very when you consider all the variables which could have an adverse effect on the continuation of your life.
Lol..
Besides, you would have more accurate and quicker control using a manual regulator.
BA Futura wagon
P38 Range Rover HSE
Posted: Wed Mar 31, 2010 11:27 am
your mums a manual regulatior she fits on the crank shaft
did some experiemnts last night, snapped up a shaft on one of my old golf clubs to use the grapfhite
just have to get the rectifyer back into my 12v 40a psu:D
found out the rectifyer is goes up to 1kv and 50 amps lol
Posted: Wed Mar 31, 2010 11:33 am
Ride: BA Futura
Right..
Just so you know my PSU has four 12V rail capable of outputting 40-50A on each.
Oh it also has adjustable voltages, etc.
BA Futura wagon
P38 Range Rover HSE
Posted: Wed Mar 31, 2010 3:48 pm
maby you will let me test 50A on each of your rails with some large resisters hmm?
Posted: Wed Mar 31, 2010 3:54 pm
Ride: BA Futura
You'll stay away from my rails..
But nah, I'm just kidding :)
Two 12V rails are 18A, the two modular 12V rails are 25A.
Specifications: http://www.gigabyte.com.tw/Products/Pow ... uctID=2490
BA Futura wagon
P38 Range Rover HSE
Posted: Wed Mar 31, 2010 3:56 pm
just to piss you off im not going to even look at that link lol
Users browsing this forum: No registered users and 72 guests
It is currently Fri Jun 06, 2025 1:52 pm All times are UTC + 11 hours
