clicking sound from engine
 Post subject: clicking sound from engine
Posted: Sun Apr 04, 2010 8:35 pm
Gallery: 14 images
Ride: 1994 ford fairmont ED
hey guys i have just recently put on some Pacemaker 4499 extractors and cat and now there is a ticking noise coming from the engine when ever im driving and its quite annoying at the moment, i just want to know what it is? and how do i solve this problem?
i do also have oil leaks one from the back of the engine and one from the front i was told they are front and rear seals have gone, the rear leak is around the back of the engine where it connects the gearbox and the one at the front is around the rocker cover, are these correct?
if anybody can please help me that would be much appreciated
thankyou
brett
 Post subject: Re: clicking sound from engine
Posted: Sun Apr 04, 2010 8:49 pm
Gallery: 21 images
Ride: EL F100 CAPRI XR EF
Power: 234 rwkw
ticking would be exhaust leak?? maybe lower flange or the gasket extractors to the head,did u fit them yourself or have a exhaust shop do it? if shop take it back
rear oil leak try rear main oil seal,possibly rocker cover
and front oil leak could be rocker cover , timing cover bolt, timing chain tensioner, crank- harmonic balancer seal,
degrease the front of the motor and check in a day or so to tell where for sure.
Posted: Sun Apr 04, 2010 8:59 pm
Gallery: 14 images
i fitted them myself and just used the original gasket that was on the car i did get another one that came with the extractors but didnt put it on, could it be that?
Posted: Sun Apr 04, 2010 9:18 pm
Power: 144 rwkw
yeah that could be the problem. shouldn't reuse gaskets. Put the new one on.
phongus = Post whore 2006
Users browsing this forum: No registered users and 56 guests
It is currently Fri Jun 06, 2025 8:30 pm All times are UTC + 11 hours
