Valve stem seals or not???
Page 1 of 1 [ 10 posts ]
 Post subject: Valve stem seals or not???
Posted: Wed Apr 21, 2010 8:24 pm
Ride: 1995 Fairmont 5 Speed
Hey guys...
I drive an ef gli with about 272000 on the clock. Any way she's beggining to be an oil abuser and smoking it out the pipe. Particularly on high rpm puffing between gears But not all the time. And also when the car hasn't been started for a few days then started and given a few revs (upto about 4000) when cold. But nothing when warm..
Been told it could be valve stem seals or whatever. Anything else it could be?
Cheers.
Sam.
FOR SALE: EBII TICKFORD HEAD. Pm me :)
TOONGABBIE MOTORSPORTS
FAIRMONT 5 SPEED BUILD THREAD: {DESCRIPTION}
FOR SALE: ford-parts-for-sale-f17/fs-things-that-need-to-go-eseries-bits-t100455.html
 Post subject: Re: Valve stem seals or not???
Posted: Wed Apr 21, 2010 8:41 pm
Ride: 1994 ED XR6, 2003 BA XR8
has it lost any power? mine does that but i have fuked rings and probably fuked stem seals aswell lol, would definately look at doing a compression test just to be sure tho.
cheers,
Tomo
98%of city drivers will say ''holly s**t'' befor going into a ditch in a snowstorm and 98%of country drivers will say ''hold my beer and watch this''
Posted: Wed Apr 21, 2010 8:52 pm
Not sure about rings and not sure about power since I converted it. haha
Posted: Wed Apr 21, 2010 8:54 pm
To a manual mind you. :D
Posted: Thu Apr 22, 2010 12:07 am
well i wouldn't imagine it would be the rings, the only thing i can suggest is do a compression test and maybee get a mate to stand behind the car while u give it a rev and see if he can smell any burning oil, unless u can smell it already lol.
just try the simple things first cos there is nothin worse than half pullin a motor appart then havin someone come up and say "yea i had the same problem, took me three minutes to fix" lol.
cheers,
tomo
Posted: Thu Apr 22, 2010 1:20 am
Gallery: 21 images
Ride: EL F100 CAPRI XR EF
Power: 234 rwkw
most likely stem seals or worn valve guides, i have the same problem in my ef ex-taxi 842,000kms
Posted: Thu Apr 22, 2010 1:22 am
Yeah got a few mates that are mech's. I'll give them a holla for a compression test. Reason why I think it's the seals is cos when it sits for a while I dare say that the oil is slowly seeping into a couple of (or could even be one??) cylinders, It causes smoke to puff out, but then there is near none or no blue smoke when you give a boot full when it's warm. But considering the hard life this cars had previous to my ownership where it's been used for towing and all sorts. So I was told... And being about 18 thou short of 300 000 kms. But by then I'll take the head off and give it a fresh start. With some added go fast bits :mrgreen: :D :mrgreen:
Posted: Sun Apr 25, 2010 4:42 pm
What does anyone else think???
Posted: Sun Apr 25, 2010 5:58 pm
Ride: Fordrunner 5.0 Turbo
You'll know if your valve stem seals are totally rooted when the car develops a miss after a mild flogging cause the spark plugs are drenched in oil.
Posted: Sun Apr 25, 2010 6:08 pm
Ride: AU falcon
here is my 2 cents, scrap the car and start again....your a boily make one....a bit of box and some checker plate.....could be boong car mk11
gumbys mavrick has box and checker plate.
5kw right there.....dont forget the black salastic
Au factory 5sp, rolling on 20'z, full custom extractors, redback cat and back. has a new motors, only 27,000ks
Welcome to Toongabbie motorsports :P
Users browsing this forum: No registered users and 26 guests
It is currently Sat May 17, 2025 7:23 am All times are UTC + 11 hours
