el putting an ed engine and gearbox what wiring do i need to
Page 1 of 1 [ 5 posts ]
 Post subject: el putting an ed engine and gearbox what wiring do i need to
Posted: Sun Mar 20, 2011 7:59 pm
Ride: el sedan
hey im putting an ED engine and manual gearbox in my el what do i need to keep i wana keep my thermo fans so do i change all the wiring harneness or what ??
 Post subject: Re: el putting an ed engine and gearbox what wiring do i need to
Posted: Sun Mar 20, 2011 8:05 pm
Ride: Territory SX TX
My god man why would you do that??? Slowest EL in existance if you go through with it. If you keep the BBM etc and all the other bolt ons you shouldnt have to change anything, but you wont have a knock sensor. If you put the ED log manifold in (GASP) then it'll be a f**k around cos you'll have to lengthen some wires or swap the engine loom. Id use the ED long motor and bolt the EL manifolds on in this instance. Or buy another EL donk. Also, if your car is an auto youre either going to have to get hold of an EL manual computer or do the auto resistor mod in the tech section.
Posted: Sun Mar 20, 2011 8:12 pm
Ride: AU XR8
first up, if the ed is a 94 model it already has an ef/el block and 94da head..
otherwise it will fit in fine you just use all the acessories and manifold from your el, no need to swap wiring or ecu's..
Posted: Sun Mar 20, 2011 11:50 pm
Ride: 1992 EBII Fairmont
I don't think early 94's did, my March 94 didn't. All the ones I've seen beyond that did though.
And it won't be much slower at all, ED motors sound a hell of a lot better too!!
Posted: Mon Mar 21, 2011 9:35 am
Ride: AU XR8
it may have only been the last 3 months of production in the ed that had the ef block and head??
i have seen a few of them and they were all 94 models..
mine is a june 94, mine must be extremely close to the last of the ed's, as im not sure what month ef started..
Users browsing this forum: Google Adsense [Bot] and 30 guests
It is currently Sat May 17, 2025 11:12 am All times are UTC + 11 hours
