What Could It B
Page 1 of 2 [ 25 posts ] Go to page 1, 2  Next
 Post subject: What Could It B
Posted: Fri Oct 19, 2007 12:02 pm
Ride: EL Falcon 4.0
hey all i am smelling fuel in my boot and while driving and i use a quarter of a tank yeasterday with in 60 k wat could it be
EL4LTR
mild cam, 2.5 inch lukey exhaust system n genie extractors,Boxed K&N Pod Filter n Big mouth intake,Rolling on 19s, slammed on superlows, shift kitted,XR6 seats,White dash insert with blue back lights n green needles
 Post subject: Re: What Could It B
Posted: Fri Oct 19, 2007 3:12 pm
Gallery: 34 images
Power: 225 rwkw
Fuel leak? :lol: i'd be checking all the hoses attached to the tank and do a visual inspection of the tank itself...
Posted: Fri Oct 19, 2007 4:13 pm
Ride: EL Falcon 4.0
could it be my fuel lines or fuel pump , injecters or oxugen sensor
EL4LTR
Posted: Fri Oct 19, 2007 4:22 pm
Ride: BA 3V Tunna
if your smelling it in the boot i'd be lifting the carpet and taking the round plate/cover off and checking the fuel lines on top of the tank
Posted: Fri Oct 19, 2007 4:26 pm
Ride: EL Falcon 4.0
is their any fuel lines or anything wat go in the boot
EL4LTR
Posted: Fri Oct 19, 2007 4:33 pm
Ride: No Fords current
Not really in the boot, but udner it.
Posted: Fri Oct 19, 2007 4:36 pm
Ride: BA 3V Tunna
if you open your boot and lift the carpet there will be a round metal plate on the boot floor on the left side.. its about 8 inches diameter its held in by about 8 screws.. if you remove that cover you will see the top of the tank and two fuel lines, one is the feed line and the other is the return line.. make sure both are connected properly and aren't leaking
Posted: Fri Oct 19, 2007 4:49 pm
Ride: 94 ED Fairmont, MY97 LE WRX
Dont forget it's pretty dark where you have to look so use your lighter to see.
Posted: Fri Oct 19, 2007 4:51 pm
Ride: BA 3V Tunna
nasty prick
Posted: Fri Oct 19, 2007 6:07 pm
Yeah it's the drugs the doctor has placed me on at the moment, i got no tolerance for stupid questions.
Posted: Sat Oct 20, 2007 1:56 am
Ride: EL Falcon 4.0
their is some water or petrol cumin out my exhaust while drivin i av been told
EL4LTR
Posted: Sun Oct 21, 2007 12:27 pm
Ride: EL Falcon 4.0
when i parked nothing leaks or anything its just the smell and bad fuel economy
EL4LTR
Posted: Sun Oct 21, 2007 1:22 pm
Check your petrol cap is on properly.
I started smelling fuel from the a*** end of my EB this morning after going for a spirited drive.
After checking in the boot and under the car I was left scratching my head as to where it was coming from.
In the end I decided to check the petrol cap and found that some C*** had undone the locking petrol cap without the key.
Now I know I did the cap up and lock it, as I had the missus with me at the time as I was teaching her how to fill the LPG,
After speaking to the local coppers I was told that there had been a raise in fuel being stolen from parked cars,
I was also told I was lucky as the scumbag C*** at the moment are even useing a cordless drill or screwdriver to puncture the tank and drain fuel.
Posted: Mon Oct 22, 2007 11:32 am
Ride: Hilux
stop asking stupid questions about what it could or couldnt be and go and check the things you have been told
Now driving a Hilux
Posted: Mon Oct 22, 2007 12:55 pm
Ride: EL Falcon 4.0
i av and its non of those
EL4LTR
Users browsing this forum: FGXR and 47 guests
It is currently Fri Jul 11, 2025 8:02 am All times are UTC + 11 hours
