dahayes |
Just a few quick questions.. im wanting to use a spare fuse slot but am unsure how this is done ie can someone give me instructions on the best way to do that?
Also im going to install an EF radiator.I understand i need to move top support for this too happen. i also need to block up the spare outlet on the radiator, whats the best way to do this? Thanks Dan |
TROYMAN |
{USERNAME} wrote: Just a few quick questions.. im wanting to use a spare fuse slot but am unsure how this is done ie can someone give me instructions on the best way to do that? Also im going to install an EF radiator.I understand i need to move top support for this too happen. i also need to block up the spare outlet on the radiator, whats the best way to do this? Thanks Dan im assuming its going in an eb or similar??? the ef radiator will fit straight in, you just need to use the ef lower coolant reservior hose, you need to make a hose addaptor to go from the eb large lower radiator hose to the smaller ef lower hose... |
dahayes |
Na going into an XG sorry Troy, i believe ive read somewheere that the outlet half way down the radiator needs to be sealed off as its not used. does this sound correct?
TROYMAN |
oh ok being an xg yea its not a straight fit...
Users browsing this forum: Google [Bot] and 0 guests |
