How to turn off interior lights when the door is open.
Page 1 of 2 [ 29 posts ] Go to page 1, 2  Next
 Post subject: How to turn off interior lights when the door is open.
Posted: Sat May 31, 2008 8:37 pm
Gallery: 32 images
Ride: BA XR6T (mix of BA, BF and FG)
Hi folks..
quick one.. I wish to put a switch in somewhere so I can turn off the interior lights when the door is open..
Often I have the door open while I'm working on something and 40 minutes later, the battery is flat..
I have replaced my interior light with a roof screen DVD and it has two big globes in it and no switch. (the factory one didn't have a switch either)
between the roof globes, the center console rear globe and the globes under the dash on both sides.. my poor battery takes a beating.. and there doesn't appear to be a switch that turns them off.
Has anyone added one?
If I can find the central positive feed that powers all the lights, it would be trivial to put a switch in it, but someone who already knows the color and location could save me allot of time.
anyone?
rgds
Frank
Posted: Sat May 31, 2008 8:47 pm
Ride: VY Commodore Wagon Accli
What are you working on? electrics? If it's stuff that isn't electric you could always just simply disconnect the negative lead on the battery.
Successful Trades with: John_XR6 (John_LS1), Private9, Schmee, Manari, Kyle_Bardell, Greenhorn (Boostedfalcon.net), FTG AUTO SALVAGE, EVL098, Gogetta, EFIII, Krytox, Blue, Smik-EL, TP351.
Posted: Sat May 31, 2008 8:57 pm
Gallery: 32 images
Yeah, I could do that.. but I have a full DVD and 5.1 surround system with time delay and all manner of other stuff.. to disconnect the battery means I must reset about 60 different settings not to mention the clock and stuff in the car itself...
rather just be able to turn the lights off.
Posted: Sat May 31, 2008 10:39 pm
Ride: 96 XH/97 EL
Try pulling the CRT LP fuse when you start work.
Posted: Sat May 31, 2008 11:17 pm
You will be looking around the BEM - you should be able to cut the courtesy lamp wire there.
Also - make sure the two rear lights are off (more current use), and have you thought of using LED's to replace the power hungry lights????
Nigel
Posted: Sat May 31, 2008 11:46 pm
Gallery: 32 images
Hi Nigel,
I've already replaced the center console rear light with an LED, and both the under dash lights as well.
will eventually do the boot and most other lights..
but for many reasons, I'd still like to be able to shut them down.. The falcons are the only car I've ever found where you couldn't turn them off.
Posted: Sun Jun 01, 2008 12:02 am
Id look at the BEM - it controls the interior light. I think a simple switch there might do the trick.
The info would be in here somewhere...
http://www.fordmods.com/forums/Upgradin ... k-d47.html
Posted: Sun Jun 01, 2008 12:17 am
Gallery: 32 images
Sweet...
I'll check it out.. thanks nigel.
Posted: Sun Jun 01, 2008 12:25 am
Gallery: 32 images
actually, my car is an EA fairmont Ghia.. so I doubt that BEM has much in common with mine.
Posted: Sun Jun 01, 2008 1:34 am
Hmmm.. fairmont Ghia? - is a maybe.
Sorry - I dont have wiring diagrams here for one (ok, I do, but they are hard copy only). Will take a look and see if I get a chance.
Posted: Sun Jun 01, 2008 10:40 am
Gallery: 29 images
Ride: ELXR8 SERIES 2
for a quick fix until you work out your switch just stick a bit of tape over the button that pops out when you open the door, that will keep the lights off while you do your work.
EL XR8 SERIES 2, 5SPD, HOT CHILLI RED, 200 ODD RWKW OF V8 FUN AND GAMES
EF XR6, 5SPD, HERITAGE GREEN, AU XR6 VCT ENGINE
VL COMMODORE, 5SPD, WHITE
BA XT, AUTO, OFFSHORE BLUE
Posted: Sun Jun 01, 2008 12:37 pm
Ride: 96 XH/97 EL
You'll most likely have a central controller (green colour ??) sitting in the dash to the left of the handbrake. Find the two black wires with blue trace - unplug the plug and test each line to earth, when you open/close a door, to find the one you want.
Posted: Sun Jun 01, 2008 2:35 pm
Gallery: 32 images
Sweet, thinks snap0964, I'll give that a shot..
Posted: Sun Jun 01, 2008 3:27 pm
Ride: 96 XH/97 EL
The wiring diagrams look at bit sketchy - looks like if you put a switch in there all it would do is defeat the lights fading out. It all depends where the wires join up.
A better bet looks like the loom going up the RHS pillar near the rear parcel shelf, this looks like the origin for the overhead lights. You should be able check this out in the boot, and maybe put a switch on the parcel shelf.
Posted: Sun Jun 01, 2008 4:30 pm
Gallery: 32 images
yeah, but would that do the footwell lights and stuff?
I figured that if there was a single point (the headlight switch) to turn them all on together.. then there should likewise be a way to turn them all off together.
Users browsing this forum: Google Adsense [Bot] and 678 guests
It is currently Mon May 19, 2025 3:32 pm All times are UTC + 11 hours
