paul w |
Got myself an annoying rattle that comes and goes, and am wondering if this is a common issue, and how to fix it.
It occurs somewhere on the inside of the dash just to the right of the instruments/inside the right-hand side mirror/above the door speaker area. As I said, it comes and goes, and I've tried pushing and pulling on the bits of plastic in that area when it happens, but without success. It's a knocking type of rattle, and bloody annoying when it occurs. Any ideas? Oh, it's an EF wagon.
_________________ EF GLi Wagon. Burgundy. Gas shocks. Rear sway bar. Nice stereo & speakers. Factory bull bar. Driving lights. Roof racks. Great car. 2nd owner. 147,000km. |
SWC |
Could be your wiring connector to your mirror or could be your window track has popped a weld. Pop the trim off and have a look. Not hard.
blueblood |
I battled a noise in that spot for the last 4 months, removed half the dash a few times with no luck until I replaced the windscreen!....A gap in the sealant somehow caused a rattle that sounded like a screw or 5cents bouncing on the dash! Although.......It has only been 3 days.
_________________ 93 EB S-XR8 5 SPEED, |
blueblood |
{USERNAME} wrote: I battled a noise in that spot for the last 4 months, removed half the dash a few times with no luck until I replaced the windscreen!....A gap in the sealant somehow caused a rattle that sounded like a screw or 5cents bouncing on the dash! Although.......It has only been 3 days. Scratch that, took 2 weeks but its back.
revcore |
I have an annoying rattle inside the drivers door....Only happens when you go over a large bump, Otherwise it's quiet. Might take the door trim off tomorrow and see if I can locate and fix the problem.
revcore |
{USERNAME} wrote: {USERNAME} wrote: I have an annoying rattle inside the drivers door....Only happens when you go over a large bump, Otherwise it's quiet. Might take the door trim off tomorrow and see if I can locate and fix the problem. I had that, wiring connector at bottom of door. Surrounded it in foam including the wire, solved it. Cheers for that....I haven't had a chance to take a look at it yet but hopefully tomorrow all being well. I know what you mean about the squeaking bushes....My EL wagon has that (Another thing I need to get stuck into).
Users browsing this forum: No registered users and 162 guests |
