Trip computer installation into EL GLi Falcon
 Post subject: Trip computer installation into EL GLi Falcon
Posted: Thu Feb 23, 2012 10:04 pm
Ride: EL Falcon
I have just installed a trip computer into my GLi falcon and while it was rather easy I noticed that the 2 wires for illumination
Pin 6 (Brown) Park Lamps Signal
Pin 7 (DarkBlue / Red) Park Lamps Dimmer Signal
don't seem to matter which way they are connected. I don't notice any difference in brightness /dimness any reason for this?
I have noticed that when the headlights are switched on that the display dims slightly. I would assume that this is so it does not appear to be brightly lit and distracting during night time driving.
After installation I noticed that the odometer globe had blown, is this because I removed it, or perhaps just because it was it's time to blow?
 Post subject: Re: Trip computer installation into EL GLi Falcon
Posted: Sun Mar 04, 2012 7:32 pm
Ride: ba fairlane ghia
hey do you need anything extra like a loom cause i got a chaser opt 20 and wanna put one in
Posted: Sun Mar 04, 2012 9:18 pm
Ride: AU Fairmont Ghia
Here... {DESCRIPTION}
Cheap pads squeal like cheap hookers, and you can take that to the bank.
Posted: Sun Mar 04, 2012 9:42 pm
Ride: EL Falcon
that's the tech doc that i used, you really need to have a spare plug that goes into the trip computer, luckily mine came with a spare plug that had wires sticking out of it so I could use some of those to hook into. To put the wires in the correct spot you need to unhook the wires from the plug(remove the white plastic piece first)
Users browsing this forum: No registered users and 116 guests
cron
It is currently Wed May 21, 2025 11:15 pm All times are UTC + 11 hours
