Auto trans temp guage?
Page 1 of 1 [ 7 posts ]
 Post subject: Auto trans temp guage?
Posted: Mon Sep 19, 2005 10:33 pm
Gallery: 22 images
Power: 315 rwkw
Location: Under the flight path of incoming packpackers
Can a kit for a trans temp guage be bought from somewhere? If so, hows it set up? sensor wise
Posted: Mon Sep 19, 2005 11:16 pm
Ride: BA XR6T
i have seen trans temp gauges, i reckon they are a good idea, cant remember where i saw it though :?
300+rwkw HeadsexTuned XR6 Turbo Ute *NOW SOLD :(*
MK Triton with 31" muddies, 2" lift and 3" turbo back exhaust etc...
Posted: Mon Sep 19, 2005 11:23 pm
Ride: Ford FPV FG F6 310
Power: 149 rwkw
you'd have to have a place to fit a sender (probably in the sump pan with a nut welded on the inside).
just a normal VDO gauge with a matching sender would do it.
wire it up and ther should be no reason why it wouldn't read like your coolant temp gauge.
What sort of temperature does gearbox oil usually get up to?
Posted: Mon Sep 19, 2005 11:32 pm
autometer make trans temp gauges. one of ym mates used to have one. and yea i think it is the same kind of sender as a coolant temp gauge
Past: 150rwkw 5spd EF Futura - 4499's, 2.5" exh, Intake, Filter, Wade 1636, Head and Valve Work, Raised Comp.
Present: 5spd AUIII XR6 VCT Ute - 4480's, 2.5" exh, Tickford Intake, Pod in Box.
coming soon: 3.9:1 diff, Flashtune.
Posted: Mon Sep 19, 2005 11:38 pm
Gallery: 22 images
Power: 315 rwkw
Dunno how hot... over 100 I spose. I was thinking of putting a T piece fitting with the sender screwed into it and mounted on the outlet of one of the coolers?
Posted: Mon Sep 19, 2005 11:41 pm
Ride: AU II Fairmont Wagon V8 Tickford
This site is good for a look, and they have an Auto Temp Kit
http://www.automatictransmission.com.au ... wsId=12031
Regards
Ray
AU II V8 Fairmont Wagon ORGANZA
Tickford Factory Suspension
HM Headers, 1/2 inch spacer
BA/F FTG Wagon Red F6 , 6 speed auto and it goes
Regards
Ray
Users browsing this forum: Google [Bot] and 74 guests
It is currently Wed May 21, 2025 4:33 am All times are UTC + 11 hours
