Timmeh |
Does air con unit in the EL have a fuse? I've just looked at the fuse box but there is nothing that says air con on it, maybe its part of some fuse?
Happy |
which fuse box you have a look at ? i think the ac fuse is in the one near the battery ..
Timmeh |
{USERNAME} wrote: which fuse box you have a look at ? i think the ac fuse is in the one near the battery ..
![]() I just looked at the one in the car. Better go check the engine one. DUrrrr. Thanks Greg. Nah its not in that one. it says HEGO, ALB, IGN, MAIN, FAN, BATT, ENG no aircon. |
Timmeh |
I've found in the manual that its a 30 amp fuse and I checked all 30 amp fuses and none of them are blown so its something else.
Happy |
there are more fuses down near the a/c under the airbox... one of them ?
Timmeh |
They are relays not fuses. Doh!
Happy |
relay schmeelay
Disco Frank |
it could be the relay pete
![]() or your car is just fooked!
_________________ RIP SCOTT |
the_scotsman |
Whats the problem with it?
Interceptor |
if the compressor isnt kicking in, it may be low on gas
_________________ Banned |
the_scotsman |
Thats what I was thinking....Installing Climate Control teaches you a thing or three about aircon lol...
Timmeh |
It was just low on on R134a. Pressure switch kicked in and didnt allow it to start. So I guess thats a tick in the box for the pressure switch functional test. lol
It was pressure tested and came up good so it I should have air con for years of motoring summer happiness. |
Users browsing this forum: No registered users and 78 guests |
