forbsy |
hey wats some suggestions for my eb2 gli any ideas? links to threads? would be muchly appreciated
_________________ eb gli 2 re sprayed in biscayne blue with sprint front lip ed xr front au series 3 side skirts sprint lip smoothed out boot garnish darkened tail lights el mirrors door handles au repeaters 17 wheels dumpd
krisisdog |
Do you have anything in particular you want to change?
eg whole dash to an EF/L piece? cluster to ef/l? AU centre console fits pretty well. Tyreshine fixes any buttons and the like which have gone grey/white. maybe some ED Fairmont/Lane seats and door trims? Theres a lot of things you can do |
forbsy |
yeh well i got two au series 2 front seats in my shed and el gli door trims and el futura rear seats and a el futura center console but can get au center consol i think they look better
forbsy |
anfd would definately do dash just depends how much time is neede to do conversion
ragga_ed |
if u havnt pulled out a dash before, give yourself a good day or 2, take your time, patiants brings perfection. it should only take you a 2-4 hours to do, BUT TAKE YOUR TIME. if you have the time, do it over a weekend, take lots of breaks and remember to breath lol
forbsy |
haha okay then but im pretty good with cars im a apprentice panel beater so ill get some one to help maybe?
PIMP_LTD |
I just did the full EF Fairmont interior swap, and i couldn't be happier with it. The conversion was quite easy, and very satisfying. I highly reccomend it. Of course if your going to retain the EB loom and convert it to suit the new dash, speak to BENJ, this is how he did it.
_________________ Commodore australia's favorite car??? What a load of s**t |
forbsy |
okay then well how hard was it changin looms?
xavier |
ive got an au center consol in mine, looks good ey, also going with the el fairmont ghia doortrims with wood grain and a power window conversion just ta give ya a couple of idears
_________________ only 2 things should come in a 2 litre, milk and juice
forbsy |
yeh i like the au console does it look good matched up 2 the el dsh?
PIMP_LTD |
{USERNAME} wrote: okay then well how hard was it changin looms?
If you mean what i did, i changed the entire dars loom, from front to back, and put all the electrics, interior and engine out of the EF in at the same time. Not too hard, just takes a day or so to run the new loom. Small amount of loom modification to do in the boot and the front right inner guard. If you mean what ben did, i think he made converter plugs so that all the EF dash switchs etc just plugged in, as for the cluster, apperantly you need to have the EF/EL engine and ECU for it to work. Unless you retain your cluster, and fit into the EF dash. It can also be easily done. Andrew.
forbsy |
can i use the el cluster if an au motor is put in?
PIMP_LTD |
If you run it on the EF/EL ECU, which is the easiest way to do it. As far as i know, everyone who uses an AU runs it on an EF/EL ecu anyway.
Andrew.
forbsy |
yeah u reckon i might do the hole loom thing
PIMP_LTD |
Well, my car was a base model GLI, it had nothing but power locks and mirrors from factory.
It now is pretty much an EF2 Fairmont, it has all its stuff. What made it easy is swapping the loom. It made it pretty much plug and play. Also i think it'd have to be quicker than modding all the EF stuff to suit the EB loom, and honestly, i'd do it again the same way. And even the price to fit all that s**t would be a fair bit, but i only paid $800 for a pretty much immaculate but front end hit Fairmont as a whole donor car. So i say, if the budget allows, DO IT. Ofcourse, it does depend on if you want the power windows/climate control and s**t, but i still woulda done it this way if the donor was only a Futura. Andrew.
Users browsing this forum: No registered users and 48 guests |
