EFford |
Age: 39 Posts: 75 Joined: 22nd Dec 2005 Ride: 95 EF XR8 & a 09 FG GT Location: Rockingham and Port Hedland |
Hey all, My heater in my EA does not get hot, when I select heat, I hear a his from the heater control, so I am assuming I have a vacuum leak at the control but I just need to know how I can remove the aircon controls from it so I can check it out, I can't seem to be able to remove the facia from around it, I undo the 3 along the top where the dash beisels are but then can't go any more.....
any suggestions..... thank you, Aaron |
OZBMX |
Hunt around for screws, theres a fair few, i can't remember exactly where they all are but there a few on obscure angles and s**t, and i think theres screws where boot release type switch bezels are etc.
As you go give it a pull to try an feel for where it's still secured etc.
_________________ Signature removed by moderator.signature must not exceed 120x500 pixles |
93EB |
Age: 47 Posts: 2486 Joined: 6th Oct 2005 Ride: 93EB Fairmont / BA Falcon XR6T Location: Western Sydney |
the last time i accessed the vacuume solenoids or control box it was behind the glove box. that box controls all that stuff. this is were it is in the fairmont not sure if its in the same place with your car or not.
_________________ 93 EB II Fairmon8 with 17' EL GT's / Clear indicators / H.I.Ds / Sports exhaust / Lowered 2' / K&N / XR6 ECU. |
EFford |
thank you all, I finally got it out, but on the back of the heater control there is one vacant connector where a hose should be, but there is no loose hoses any where that may of come off, yet when I move the control to heat, the spare hole hisses (sucks)...... I am not sure, basically my heater does not work at all, I ever so slightly get a real faint warm air out of the drivers side vent by the door yet all the rest a freezing cold......does any one have an idea...???
thanks, Aaron.... ![]() |
Users browsing this forum: No registered users and 57 guests |
