largey |
i press the cruise button the light comes up but the speed does not set anyone got any suggestions thanks
_________________ ef futura in the process of doin her up nice and neat it will be |
KWIKXR |
Did you set the speed at which you want to cruise at? I dont know much about cruise control cause i dont use the thing, id rather cruise my own way
largey |
yes i set the spped as well and it wont like adjust speed or anythin
Krytox |
Must be above 40kph.
Check brake lights. (faulty switch will void the cruise) if brake lights are on. wrong tail light globes will also render the cruise if parkers are on.
largey |
might be the break bulbs give them a squiz
FORDom |
u gotta press + for it to set..(if u didn't realise)
OZBMX |
{USERNAME} wrote: u gotta press + for it to set..(if u didn't realise) That was pointed out and dismissed at the top of the page already, maybe hold fire on your replies a moment or 2 ![]()
_________________ Signature removed by moderator.signature must not exceed 120x500 pixles |
stanbu |
I have the same problem with mine at the moment. It won't work at all if I press the + button. Was like that for a week, then I pressed the - button at it worked. The + button still doesn't work but I can use the cruise control by activating the - button. Still need to fix the problem though.
Stan |
metasaiah |
My cruise system shat itself last year. First I replaced the buttons on the wheel; got no luck there so I replaced the brake-actuated deactivation switch and the actual cruise control unit. Worked fine after that. I bought all the bits off eBay and spent about $100 all up; fitted everything myself, which isn't as hard as it seems.
_________________ EF2 Fairmont Ghia. AU2 engine running EF gear. Intake, exhaust, injection etc; 8" rear stockies with 265/50R15 rubber. Shiftkitted auto, J3, custom grille and dash cluster and lots of other useless crap... |
clampy |
mine not working either light comes on thats it i replaced the brake activation switch....
_________________ EL Futura 5 speed factory:PH47FL goneeeee |
V8 Ghia Mike |
{USERNAME} wrote: mine not working either light comes on thats it i replaced the brake activation switch.... Sorry mate, can't quite understand what you are saying. Did you fix it? Mike
_________________ EF Ghia 5.0 - XR8 in a tuxedo....classy, low and loud |
clampy |
nah i havent fixed it
stanbu |
Hi,
There is a doco in this forum detailing how to install cruise control. It also contains detailed step by step fault finding information. I'm sure if you follow this you will be able to fix your problem. Stan |
stanbu |
V8 Ghia Mike |
Thanks Stan!
Mike
Users browsing this forum: No registered users and 62 guests |
