cruise light comes on, doesn't engage
Page 1 of 2 [ 28 posts ] Go to page 1, 2  Next
 Post subject: cruise light comes on, doesn't engage
Posted: Tue Mar 28, 2006 11:32 pm
Ride: '95 EF's
hey all
in the wagon - the 'cruise' light is on, but then pressing 'set +' or 'set -' the cruise doesn't engage! dammit!
tell me why! lol - it was working a few weeks ago, and the buttons all work perfectly, so i'm lost :?
R.I.P. Scotty
Posted: Tue Mar 28, 2006 11:39 pm
Ride: EF Gli Ghia, XP Fairmont
you've got my bloody ford manual volume 2 which has all the cruise control stuff in it and your posting this question????? lol
Owning 1 of 67612 EF GLi Sedans made
FACT: "Chuck Norris owns the greatest Poker Face of all-time. It helped him win the 1983 World Series of Poker despite him holding just a Joker, a Get out of Jail Free Monopoly card, a 2 of clubs, 7 of spades and a green #4 card from the game Uno."
Posted: Tue Mar 28, 2006 11:43 pm
Ride: '95 EF's
i discovered it on the way to a mates where i am now! so i don't have the manual with me, and i have no electricity at home to read it even if i was there! :P
R.I.P. Scotty
Posted: Tue Mar 28, 2006 11:44 pm
you are a dissapointment Robert!
Posted: Wed Mar 29, 2006 8:37 am
Ride: SF5 Forester
you will or would find the cable going to the throttle body is probably stuffed
R.I.P Tobias my son.
Posted: Wed Mar 29, 2006 9:15 am
Gallery: 9 images
Ride: Blue and White Mercedes
Hmmm, It could be the brake light switch.
If not, the cruise control uses a back-up switch, to dis-engage the cruise control when the brakes are applied.
This switch is on the Booster. I have had an issue with the switch on the booster, so mine did exactly the same as you are describing.
Hope this helps
Chris
Remember kids, the more pages of crap in your build thread, the bigger your e-penis is
Posted: Wed Mar 29, 2006 8:02 pm
Ride: EL Fairmont
Mine is doing the same thing.
i have already installed a new break switch so it can't be that.
What are the other options?
96 Fairmont
XR8 bodykit and wheels
Lowered
Looking to do more upgrades
Posted: Wed Mar 29, 2006 8:03 pm
Ride: EL Fairmont
Where is the booster?
96 Fairmont
Lowered
Posted: Wed Mar 29, 2006 8:05 pm
Ride: '95 EF's
it is irrelevant if the brakes are applied, so it won't be the switch i'd imagine?
R.I.P. Scotty
Posted: Wed Mar 29, 2006 8:52 pm
Ride: XY Fairmont
Check the brake light switch and fuse, if they are ok, try a new set of buttons.
Real Cars have Chrome Bars
Posted: Wed Mar 29, 2006 9:41 pm
Ride: LS3 VF
the stop light switch and the other brake switch are default to the "off" position so that if one of them fails or both of them fails the cruise just wont work, as opposed to not turn off when u put your foot on the brake... first thing to check is are the brake lights on all the time... the stop light switch on the pedal box is the most common cause...
Posted: Wed Mar 29, 2006 10:19 pm
Ride: 96 XH/97 EL
Not correct, brake pedal switch is normally open as stated, but the master cylinder switch is normally closed.
All I can suggest Fraser is you check the cruise control servo, that the cable and the attachment is secured properly - it is fitted and rotates clockwise, and clicks in - check that it hasn't come loose.
The areas that can cause what you have:
1. Brake pedal switch - okay as you have said.
2. Clutch switch wiring blank plug for auto's (see below).
3. Master cylinder switch - pull the plug, short with wire, go for a drive.
Electrically, using Greg's manual, pull the cruise servo plug - you can continuity check everything in the system bar the servo itself if you have a decent cct diagram to follow, without pulling things apart, get someone to operate brake pedal and steering wheel switches. This will also check if the clutch switch wiring is shorted properly with the auto plug as well.
Posted: Wed Mar 29, 2006 10:50 pm
Ride: XY Fairmont
Not 100% sure, but I think that if the brake light fuse is blown the cruise wont engage.
Posted: Thu Mar 30, 2006 2:51 am
Gallery: 25 images
Ride: BA on gas. EL on gas. XF on gas.
No fuse no cruise. The switch on the brake booster was F**k on mine not long ago. (it is the backup switch and even if unplugged cruise will not engage)
Member Number 8804
Posted: Thu Mar 30, 2006 8:55 am
Ride: Reindeer
id say sell it and buy a FBT..... but anyway......
Its people like you that make people that kill other people, sleep easier at night.
Users browsing this forum: No registered users and 63 guests
It is currently Tue May 20, 2025 5:18 pm All times are UTC + 11 hours
