choppybd |
Hey, im gettin a bare xr6/xr8 leather wrapped steering wheel. Ive got an EF futura, was just wondering how easy and compatible it is to attach the ef air bag and cruise control switches.
Cheers Troy |
madmax |
What model XR is the wheel out of?
If it EF,EL or AU it will swap straight over.
choppybd |
yeah it says will fit any ef,ef,au.
was just wondering how you remove the centre section from my original steering wheel |
uglybob |
the airbag section?
lol doing a doco on this is next on my list! might go out & do it now actually... but there are 2 x 10mm bolts on the beck, underneath a clip on either side. you need a T-50 torx bit though to take the wheel off
chunkz |
ok
i have done this so i can help for once (didnt even f**k this one up fellas) ok unclip the battery.... or the airbag fuse grab a stubbie and wait 5-10mins (this will stop the airbag from breaking your neck if it goes off) their should be two clips behind the steering wheel, remove them and undo the screws the airbag should come off now from memory... lay it down so the bag faces up... be very gentle with it... unplug the horn n s**t... and undo the weird looking screw thingy which is a t-50 torx screw or something? any ways once that comes off its pretty easy just use some elbow greese and bang the top of the wheel, then bottom, then right, then left takes a bit of work but it'll work out and then yeh Im pretty sure thats it, i did this mod in like dec, so im a bit hazy
choppybd |
cheers guys i will have a stab at it next weekend coz havnt got the other wheel as yet.
Thanks Troy |
madmax |
Follow chunks instructions, he's got it right.
Just don't completely remove the T50 torx bolt until you have the wheel loose or you'll end up wearing a steering wheel in you face, when you eventually pull it off. The wheel can be difficult to remove.
twirqurky |
A bit off topic, but take uglybobs advice over chunkz's. Chunkz has it right but knowing him he prolly copied it from elsehwere
uglybob |
i've written a doco w/ instructions & photos - has been sent to matti, so should be up soon!
chunkz |
{USERNAME} wrote: A bit off topic, but take uglybobs advice over chunkz's. Chunkz has it right but knowing him he prolly copied it from elsehwere
![]() talkig to darren and like 1 more phone call to him when i got stuck so shove it ya C*** ![]() ![]()
Users browsing this forum: No registered users and 188 guests |
