LOWER MESH FOR EF XR8
Page 1 of 1 [ 13 posts ]
 Post subject: LOWER MESH FOR EF XR8
Posted: Fri Jun 10, 2005 1:40 pm
Ride: EF XR8
I'M TRING TO FIND A COMPANY THAT MAKES THE LOWER MESH FOR YOUR FRONT BAR LIKE THEY HAVE ON THE NEW GT'S AND GTP'S BUT TO FIT A 95 XR8 ANY HELP WOULD BE GREAT.
Posted: Fri Jun 10, 2005 4:21 pm
Ride: EL Series 2 XR8
I'd be interested in something like this for my el xr8 too if anyone has some info.
Might have to be a DIY job?
Posted: Fri Jun 10, 2005 4:23 pm
Gallery: 18 images
Ride: EL Falcon GLI
make it a DIY and then show us how you did it :)
Buy my car :) cause i just bought a BA XR6 :)
Posted: Fri Jun 10, 2005 4:43 pm
Ride: EF XR8
I HAVE HAD SOME INFO ON GETTING THE LOWER GRILL FOR THE FRONT BARR I WILL KEEP YOU POSTED ON WHERE TO GET THEM AND WHAT IS NEEDED FOR THE JOB AS I FIND OUT MORE.
Posted: Fri Jun 10, 2005 6:08 pm
Ride: eb falcon s series 2
mesh u talkin about???
\SUPERCHEAP AUTO mate
they have heaps of colours too.
Posted: Tue Jun 14, 2005 2:23 pm
Ride: XR6T
I have done this to my EF - in white mesh.
check out my gallery if you wanna see pics?
Took the front bar off and attached it from the inside.....
"This is FORD country.... Where on a quiet day you can hear the HOLDENS rusting...."
Posted: Tue Jun 14, 2005 2:26 pm
Ride: 1994 ED FALCON FUTURA
True. Also check out Malz in Cannington. Im pretty sure they have plenty of mesh there aswell. Anyway good luck, and give us pics when yah done.
Posted: Tue Jun 14, 2005 2:39 pm
Gallery: 18 images
Ride: EL Falcon GLI
damnit, Adz i want those headlight protectors! i want them for my EL! i found some for an EF, but not an EL!!!! GRRRRRRR
Posted: Fri Jun 17, 2005 1:46 pm
Ride: EF XR8
SORRY I SEEM TO OF MISS LEAD YOUS I WAS CHASING THE MESH GRILL AS SEEN ON THE XR 8'S AND GT'S THAT HAVE THE WORDS STAMPED THROUGH IT ,I HAVE HAD SOME INFO ON DOING THE JOB AND I WILL TRY IT OUT AND GET BACK TO YOUS AS IT HAPPENS AND WHAT IS NEED AND THE COST COMPLETE WITH PICS.
Posted: Fri Jun 17, 2005 1:53 pm
Ride: '95 EF's
i've contacted some people in regards to these - as far as i know, no-one makes a production-run of these at all for EF/EL's yet - only the BA's :? so if you can find someone, good luck - if not, i'd be doing something custom!
P.S. - caps lock is your friend :P
R.I.P. Scotty
Posted: Fri Jun 17, 2005 2:03 pm
Gallery: 17 images
Ride: Oettinger Golf GTI
www.melwire.com.au
or any alloy place that sells mesh or whatever, thats for high quality alloy grade or mild steel instead of el cheapo .. its about $50-80 per lineal metre..
Posted: Fri Jun 17, 2005 2:28 pm
Gallery: 37 images
Ride: V8 EF Futura
Surely not difficult to source the mesh and create some sort of stencil which can be used to paint whatever you want on there?
Posted: Fri Jun 17, 2005 3:19 pm
Gallery: 17 images
Well if you decide you want to get your own design you can go to for example in Sydney, liverpool exhausts, next door inside there complex is a laser metal cutting place which laser cut metal flanges etc etc u get the drift.
realistically you can get some say 3-5mm thick sheet and ask them to cut it with your name in it or whatever providing u have the design and them not ask for a jig to be setup (costs) etc.
otherwise melwire or whoever as i said and just put a badge infront or get a pair of tin snips and cut out what u want said?
It is currently Sat Jun 21, 2025 7:39 pm All times are UTC + 11 hours
