falcon_3512003 |
Can anyone tell me if ba side skirts will fit onto an au if mods are needed let me know i can do them just need to know if they will fit cheers
_________________ now have a series 1 au starting the mods slowly |
SWC |
BA Skirts are longer than the AU, by about 40mm if my memory is right
![]() Do it at the front, cut about 30mm from the front, cut out the required amount and rejoin them. EFFalcon and I have done it and I am sure others have as well. |
falcon_3512003 |
Ok cheers will do that that sounds easy enough i do a bit of panal work so thanks for the heads up
falcon_3512003 |
Just o give you guys heads up its the rear to cut if you cut the friont the ruber strip that runs from front to rear door wont clip in the holes into the sill so cut the rear and 40mm was spot on to cut off cheers
