uglybob |
hey all
got a pair of these off a mate - they won't fit his EF XR headlamps, only my EL XR front bar - they have 'DRIV OUTER' and 'PASS OUTER' on them - its a plastic protector w/ a rubber surround, and a red 'XR' at the bottom - only have the outers, not the ones for the high-beams - anyone else seen these before, or know where to get 'em? ![]() {DESCRIPTION}
twirqurky |
Good thinking. I am worried about breaking my glass headlights now.
Happy |
have you rung Ford?
EL XR8 |
They look like the Headlight Protectors for the AU Series XR's.
I'm pretty sure they weren't made for the EF/EL's. Dave |
Happy |
if they go on the same way the AU's did you should forget it - they look ugly i reckon
uglybob |
{USERNAME} wrote: if they go on the same way the AU's did you should forget it - they look ugly i reckon
no they don't - they clip right up onto the glass pretty much.
Happy |
ahh in that case I might be interested too, go find out if they are still made!
twirqurky |
Run quick young Fraser and return with word from your adventures.
Black Betty |
We had to replace some on a damaged falcon about 2 years ago and you could still get them trough ford then.
GlennBA |
{USERNAME} wrote: They look like the Headlight Protectors for the AU Series XR's.
I'm pretty sure they weren't made for the EF/EL's. Dave the au xr ones don't have that logo. They definately are different |
Trick Flow EL |
A bloke in the NSW FPV club has them on his EL XR8 and the appear to fit to the light openings on the front bar.
They could be attached to the glass itself as there is not much room between the light and bar. I will have to chase up a set now.
_________________ EL2 XR8 Auto 13.64 @ 100.76 MPH with a 2.05 60ft. Now sold! |
Users browsing this forum: No registered users and 34 guests |
