romp |
i was wonderin if anybody knows if territory whells will fit pre-AU falcons, i have seen territory steel wheels on a toyota hilux and have been told that that model toyota has the same stud pattern as pre-AU falcons, can anyone tell me if they fit please? thank you.
nomad1089 |
I think the toyota has the same stud pattern as AU, you could get them to fit with spacers or hub adaptors
_________________ "12 yards long, two lanes wide, 65 tonnes of american pride" Fairlane
romp |
thanks, do you know any way that i could find out
JOSE |
using this logic territory= BA/AU studpattern and offset, AU/BA wheels dont fit PRE AU (well sorta) so NO they wont fit straight out, but they could fit either with hub adapters, OR getting them modified (centre has to move 28mm inwards)
_________________ Because i can. |
fuzion |
the 17s are 17x7.5 so i think they'l rub in the guards on the rear, and on the front no chance
ive tried on mine .. ! but with some toyota, i think pre 87 or something will fit, something like that.. ring your local tyre/wheel joint |
Mechan1k |
I saw a set on a mid-to-late 90s 2WD Hilux ... but still with the Territory tyres on it ... and lowered ... looked strange ... I would have thought the owner would have changed the tyres to the size needed.
![]() Here's what they look like an on AU anyway with 235/45R17 rubber (ute has been lowered since this pics though) Spacers should work ... not sure on the legalities in your state though
_________________ 04 Territory TX AWD - Winter White - optioned up |
