Electric Bonnet Release
Page 1 of 1 [ 11 posts ]
 Post subject: Electric Bonnet Release
Posted: Fri Dec 29, 2006 6:37 pm
Ride: BOXCAR
I have figured out how have an electric bonnet release using a NA fairlane boot release soleniod + cable and latch mechanism
It also has provisions for a manual backup as well.
my question is, the car i am fitting this to has no rego, will the RWC people crack the s**t becuase its electric even if it has a manual back up (that will be hidden under the mudguard)
this is for pure wank factor :P :P :P
^^^ What He Said
Posted: Fri Dec 29, 2006 9:53 pm
Ride: No Fords current
I doubt you'll have an issue, specially here in Tassie!
Posted: Fri Dec 29, 2006 10:48 pm
Ride: '99 XH XR6 5 SPEED
i spoke 2 a guy in melbourne about my car because i would like to replace mine with an electric boot release and he said it should be no probs.
SIGNATURE REMOVED DUE TO BREACH OF GUIDLINES.
Posted: Sat Dec 30, 2006 2:19 am
Gallery: 20 images
Ride: EA Falcon & G220 Lane
intresting mod
any more info on this??
4.0lt Balanced Bottom End, ACL Race Internals, Rspec4 Cam, BPT Swichchip, PH4480, 2.5' Lukey, Scorcher Bodykit, T5 Manual
237RWHP
LOLLOLLOLLOLOLLOLLOLLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL
Posted: Sat Dec 30, 2006 9:52 am
Ride: EFII Sedan
I think there is an australian standard that requires a bonnet to have a backup lock (the one you have to flick while you lift the hood). So long as you incorporate that, it should be legal
EF II Sedan
Ex Chaser, Dual Fuel (Impco LPG)
LSD High, 3.23, Black wheels, other shiny bits.
EB II Sedan <--- R.I.P. (Rest in pieces - gone to the wreckers for $50...... bargain!)
Posted: Sat Dec 30, 2006 10:00 am
Ride: EFII Sedan
Just found it:
From the Australian Vehicle Standards, 1999
Bonnet Securing Devices
(1) A motor vehicle with a movable body panel forward of the windscreen that covers an engine or luggage storage or battery compartment, must have a device to secure the panel.
(2) However, if the panel opens from the front in a way that partly or completely obstructs the driver's forward view through the windscreen, the panel must have primary and secondary devices to secure the panel.
This would be a good addition to a car alarm - inhibiting them from fiddling with your engine bay when trying to get the car started. I would move the manual release to somewhere inside the car though.
EF II Sedan
Posted: Sat Dec 30, 2006 10:02 am
Ride: EFII Sedan
I don't think they would worry about the location of the manual release, as the old Mini's can be opened from the front from factory.
EF II Sedan
Posted: Sat Dec 30, 2006 10:28 am
Ride: BOXCAR
Cheers for that mate.
Here are some prick teasers for those who are interested
as you can see the cable is very similar to the manual one, and the soleniod has a flat bracket so it can be bolted anywhere thats a flat surface.[/img]
Posted: Sat Dec 30, 2006 10:38 am
Ride: EFII Sedan
Are you using the existing bonnet latch, or using the boot lock entirely?
It takes a fair bit of force to pop a bonnet latch.
EF II Sedan
Posted: Sat Dec 30, 2006 11:07 am
As stated, it takes a bit to pull a bonnet latch, maybe a heavy duty popper...something like the rocket ones from Repco, they seem to open doors easy enough.
I`d imagine the laws are similar to door latches...solenoid operated must have mechanical backup...dunno though...
JAIKAI
Posted: Sat Dec 30, 2006 11:08 am
Ride: BOXCAR
i am going to try and use the existing latch. I don't see any other way of making legal without using the original latch
the thought of the soleniod not having enough pulling power has crossed my mind...
Mabey i could put a bit of CRC into the bonnet latch to lub it up and make it turn a bit easier :?:
It is currently Tue May 20, 2025 4:41 am All times are UTC + 11 hours
