EFairmanual2088 |
heya ppl anyone know if you can get glass headlights units either custom made or whatnot for the EF monts. i bought a set of hid headlights for my car but am afraid theyll melt the standard plastic units.
lukey |
Not that I've ever heard of or seen!
twase |
HIDs are better than the standard globes for heat so don't worry.
_________________ BF Fairmont Ghia Series II update. |
fordfreak ef |
melting of the lese is dependent on what globe you choose to run.. ive run a high wattage pair before and found out te hard way.. (extra heat = melted lense's)
as far as i know.. they would have to be custom made... there's no raedy made glass replacements as of up to now.... |
EFairmanual2088 |
globes i will be running are 8000k will they run too hot for the standard lens
Krytox |
HID's run brighter with less heat.
Problem is the E series headlights they can't seem to project the light. Sure, they'll be heaps brighter, but don't expect a great increase in visibility. And the polycarbonate will be fine with 6000k, 8000k etc. 100watt halogens will affect the lense/poly. 8000k is kinda purple tho.. 4500k is much better.. imo
Macca |
{USERNAME} wrote: HID's run brighter with less heat.
Problem is the E series headlights they can't seem to project the light. Sure, they'll be heaps brighter, but don't expect a great increase in visibility. And the polycarbonate will be fine with 6000k, 8000k etc. 100watt halogens will affect the lense/poly. 8000k is kinda purple tho.. 4500k is much better.. imo I haven't fitted HID's to my Fairmont yet (got to fix the yellow first ![]() I will be fitting them to the Fairmont but I will be using high/low H4 HIDs and just Plus 50 H3s in the driving light part, that allows me to flash the lights without a delay.
_________________ 93 Ford Maverick LWB automatic petrol guzzler (gets stuck where Deli doesn't, big pumpkins |
EFairmanual2088 |
yeh that nasty yellow stain that magically appears on the polycarb. you can get them cleaned for about $60 a unit and they give you a paste to apply to them every 6 months to stop it from reoccuring.
Krytox |
Or you can follow the completely destroyed tech doc:
http://www.fordmods.com/forums/documents.php?doc=58 and do the pair yourself for around $30
