Drivers door drop
Page 1 of 1 [ 8 posts ]
 Post subject: Drivers door drop
Posted: Fri Sep 26, 2008 5:28 pm
Appreciate some advice please. Drivers door on my EL has dropped letting in water. Can the door be adjusted ? If the hinge needs replacing could you give me some tips please. When the door is closed there is a gap between the rubber and door. After opening the door it drops about 25mm. The locking bar on the center pillar is starting to chewed by the door lock.
Posted: Fri Sep 26, 2008 7:26 pm
Gallery: 20 images
Ride: EA Falcon & G220 Lane
sounds like common dramas with ford hinges
needs replacing thats the most simple answer can still buy new im sure through most aftermarket supliers & or ford spare parts IIRC
4.0lt Balanced Bottom End, ACL Race Internals, Rspec4 Cam, BPT Swichchip, PH4480, 2.5' Lukey, Scorcher Bodykit, T5 Manual
237RWHP
LOLLOLLOLLOLOLLOLLOLLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL
Posted: Sat Sep 27, 2008 9:22 am
Thanks biggav. Is this a job for a panel beater? If not any advice on how to change the hinge. Should both be done?
Appreciate the advice
Posted: Sat Sep 27, 2008 12:20 pm
Ride: EF Fairmont II
Have a look at the hinge mate....
If you can see what needs to come out ie 2 bolts and a pin etc if you can do that then do it if you cant then get a mate or something a beater will charge $100 or more for a 10 min job.
Il take a look at mine later on and see if i can give better advice.
Posted: Sat Sep 27, 2008 2:39 pm
Thanks sideways. I'm stuck in a wheelchair and my wife will be doing the repairs. That is the reason I appreciate any advice.
Posted: Wed Oct 22, 2008 11:50 am
Ride: XH XR6
sometimes its not the hinge, it can be the panel around it. Just had the XH done and the hinge was fine but all the panel around the door and cab itself had broken away. because of the central locking problems it was easier to get the panel beater to do it. charged 150 bux and he basically cut the panel off, welded in new sheet and put the hinge and brackets back on.
If it's got tits or wheels, it'll give you hell!!!.....
Posted: Wed Oct 22, 2008 9:13 pm
Ride: BA XR6
i agree its better to get a panel beater to do it i used to be one and we dealt with this s**t every day. if youre in a wheel chair and the wife is doing the repairs i really would take it to a panel shop, not saying girls are useless but its also a lot less demanding by taking it to a shop. hope it helps.
Go The Mighty Falcon.
2004 BA XR6 FORD FALCON
COLD AIR INTAKE, FLASH TUNER, 2 1/2 PERFORMANCE EXHAUST, JOHN BOWE SIGNATURE SERIES BILLLET THROTTLE BODIE, REFLECTIVE TINT, CLARION 5X7 WITH INBUILT CAPACITOR,NOW WITH FUSION ENCOUNTER 10 IN SUB+AMP, RED SMOOTH CALIPERS, BUT STILL ONE NUTS DRIVER.
Posted: Thu Oct 23, 2008 3:58 pm
Thank you for the advice Shop it is.
Wheely
It is currently Sat May 17, 2025 9:01 pm All times are UTC + 11 hours
