fitting xr-6 lights to a fairmont ???
Page 1 of 2 [ 20 posts ] Go to page 1, 2  Next
 Post subject: fitting xr-6 lights to a fairmont ???
Posted: Sat Sep 05, 2009 12:05 am
Ride: fairmont el
i am after better lighting for my el fairmont. can i fit xr-6/8 headlights to the car and what do i have to change e.g. bumper, bonnett, etc
 Post subject: Re: fitting xr-6 lights to a fairmont ???
Posted: Sat Sep 05, 2009 12:51 am
Gallery: 18 images
Ride: Envi EF
http://www.twinlight.com.au/
I'd be looking at that mate.
>>>{DESCRIPTION}<<<
Posted: Sun Sep 06, 2009 12:06 pm
Gallery: 9 images
Ride: Blue and White Mercedes
^^ What he said.
This is my set
otherwise, you will need the lights, blinkers, bonnet, front bar, and I think that the bonnet latch was different too.
Remember kids, the more pages of crap in your build thread, the bigger your e-penis is
Posted: Mon Sep 07, 2009 11:23 pm
Ride: fairmont el
$650 from them. Does anyone know how much a bonnett,bumper and lights are from a wrecker?
Posted: Tue Sep 08, 2009 1:06 am
Gallery: 21 images
Ride: EL F100 CAPRI XR EF
Power: 234 rwkw
i have seen some xr fronts at wreckers for $500 upwards, without bonnet etc, just bar, lights and indicators, bonnets sell for $150 upwards. then u probably need the bits painted to match too so extra $$$
u may be able to find bits cheaper too. ring around,... ebay too
Posted: Tue Sep 08, 2009 7:26 pm
Gallery: 9 images
Ride: xc wag's, tnklane wag's
Yeah agreed xr front conversion isn't a cheap avenue, considering the indicators are worth 200-250 new and aftermarket not offered, it's not as suprising as you'd think that they've been known to steal them. :lol:
Signature removed by moderator.signature must not exceed 120x500 pixles
Posted: Tue Sep 08, 2009 8:00 pm
Gallery: 18 images
Ride: Envi EF
From a wrecker you'll be looking at well over $1k... well, well over.
>>>{DESCRIPTION}<<<
Posted: Wed Sep 09, 2009 9:09 am
And not only that, the light output from the XR lights, is not considered to be as good as the Fairmont lights.
The Twin Lights however, are very good.
BenJ
{DESCRIPTION} - Current Ride
{DESCRIPTION} - Previous Ride
Posted: Wed Sep 09, 2009 9:31 am
Ride: EL XR6
and then the high beams are still crap too
My Herrod motorsport/Tickford EL XR6
Posted: Wed Sep 09, 2009 9:55 am
Ride: ef futura/ef fairmont
i can't complain my set i picked up are great, no problems with the lighting of them, actually lights up better then my futura. as for price i payed $600 for the lights and indicators. As for the bonnet you can just use a gli bonnet and bonnet latch.
custom airbox,custom intake
paccie comps,lukey 2.5 cat back,high flow cat
CMS stg2 head,CMS stg2.A. cam,CMS hybrid auto with mod shift,3.9 lsd
custom 3500rpm hi stall
ANZ mayhem 18's,custom interior,venom body kit,xr wing,jumbo 2' low springs
143rwkw and 407rwnm on CMS dyno
Posted: Wed Sep 09, 2009 10:22 am
Ride: EF Fairmont Sedan
Power: 180 rwkw
This is my set
Have you got more pics as that looks ORSM :)
I need to get a set of twinlights as my new Air Box feeds Cold Air off the back of the headlight and if I add the Twin Light Set then there is two more holes for Cold Air to get in
PROEF 13.46 @ 105.78mph - 1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
Stock Fuel Pump, 29lb Injectors, JMM Street Series Headers, 2.5" Exhaust, 205rwkw
Posted: Wed Sep 09, 2009 11:10 am
Mate
There is a place in melbourne that supplies changeover headlights just ask a panel beater they maybe able to upgrade your el headlight reflectors and install brighter globes
gassa
When the clutch drops the bull s**t stops!!!!!
Posted: Wed Sep 09, 2009 11:37 am
Power: 180 rwkw
Mate
gassa
This Guy
Quote:
Or you can get some FORD GENUINE EF EL Fairmont Headlights, Change over and fitted and aimed correctly from {DESCRIPTION}
Old and NEW
Old and NEW
Posted: Wed Sep 09, 2009 12:51 pm
Ride: 96 XH/97 EL
Or you could have a go similar to what this guy is doing:
exterior-modifications-f15/el-fairmont-hid-retrofit-t79728.html
If you hunt around, you should be able to get parts considerably cheaper than a twinlight or XR conversion.
Can give you something unique, and most people won't try it due to the work involved.
Posted: Wed Sep 09, 2009 2:09 pm
Gallery: 20 images
Ride: ED Falcon
Power: 133 rwkw
from my understanding EF/EL XR lights are the same as ED ones... I thought all EF and EL lights were crap as they are only like 3 or 4 inches high? my ED XR ones are great, although I've never tried them with normal bulbs but 35W HID are pretty good and light up the road nicely... although I've never adjusted them as yet and am probably lacking a bit there... but other than theat they seem pretty good...
I was gonna buy some ED twinlights off that guy and he said to me that his lights were as good as the genuine ford projectors so I went for genuine conversion...
look at this page: http://www.twinlight.com.au/twinlightsp ... .htm#ED_XR
and you see genuine replacement low beams are $168ea and highs are $152 whereby the bulbs he uses in his are $27.50ea for both high and low... so from that, I guess that genuine bulbs would be much better...
however...
at least for the EL twinlights you can get them in projector... showing $172 and $135 for low and high beams respectively... so you guys might be better off going that way...
up to owner I guess... some like the look with compromised light output (probably not all that important if you rarely travel outside of well lit up towns) or then you get those who don't care how the car looks and have dirty great big bull bars with lights hanging off them everywhere...
It is currently Sat Jun 21, 2025 7:04 pm All times are UTC + 11 hours
