fibre glass rear bar small craks
 Post subject: fibre glass rear bar small craks
Posted: Sun Sep 20, 2009 9:45 pm
Ride: xr6 au 111
hey guys got a new rebel fibre glass kit on my au but i have a few small craks in the rear bumper how can i fix them i have herd about septon fibreglass filler i dnt have a clue how to use it ,any one no?
 Post subject: Re: fibre glass rear bar small craks
Posted: Sun Sep 20, 2009 9:52 pm
Gallery: 34 images
Power: 225 rwkw
got any pics of the damage??
Posted: Sun Sep 20, 2009 9:59 pm
Ride: EF Fairmont
Reinforce the bar from the back with additional layers of Glass. Always best to reinforce the bar, may even be worth adding a bit all the way along the inside ogf the bar. Do you have pics of the Damage, inside and out? Clean out any loose fibers etc on the outside and put down small layer of Fiberglass, sand and fill with filler and finish. You can use fiberglass filler to fill the joint / hollow after you reinforce the bar with glass but you will need power tools to sand it, it is as tough as nails, I use sanding disks on a variable speed angle sander, also orbital and palm sander starting with 60 grit and working down to 120 grit. I use nothing finer on bare Glass filler or Fiberglass. I then filler with std filler and sand as per normal. If you use Glass Filler you will need to treat it just like fiberglass when sanding and get ready to itch :lol:
It is currently Sun Jun 22, 2025 2:38 am All times are UTC + 11 hours
