removing front bar
Page 1 of 1 [ 9 posts ]
 Post subject: removing front bar
Posted: Thu Nov 25, 2004 8:41 pm
Ride: EF Falcon 95
can anyone tell me how to remove the front bar of my ef? i just need to know the location of all the bolts holding it to the car as ive had a look around and cant seem to find many, dont really wanna spend all day looking for the bolts to take the bastard off. also is there anything else i need to remove in order to get the front bar off?
Cougar Zero makes my pants fit nice.
Posted: Thu Nov 25, 2004 8:59 pm
Ride: EBII 220kw Tickford powered.
Ok, from memory-
You will need to remove/undo, not in this order
1. the forward (not the large one that goes over the wheel) inner guard, probably 4-6 screws either side.
2. two nuts/bolts either side inside the wheel well, at where the bumper mates up with the front guard
3. the two nuts inside, either side of the bumper scoop (where you can see the radiator).
4. any screws where the bumper attaches to the forward radiator cover/shroud.
5. the horn wires and if you have Auto climate control, the sensor. Both of these run into a common loom that joins just infront of the rad support.
I think I got everything.
The car should be called "Frankenstien". EBII GLi skeleton, AU T2 220kw heart, AU2 brain, EF/EL for everything else.
"Bitza" Member 28 on FORDMODS v1.0 Joined 28-04-2002
"TS50EB" Member 300 on FORDMODS v1.1 Rejoined 6-11-2004
Posted: Thu Nov 25, 2004 9:41 pm
Ride: EF Falcon 95
cheers mate, made next sunday alot easier for me!
Posted: Thu Nov 25, 2004 10:13 pm
No probs, good luck
Posted: Fri Nov 26, 2004 12:00 am
Gallery: 33 images
Ride: EL Fairmont Ghia
i have had front bars off and on the last couple of months, i can take some photos if u like just pm to remind me or something
Posted: Fri Nov 26, 2004 11:23 am
Ride: EFII Futura
I done it last week on my EF....
Remove inner front guard covers
Remove the cover between the top of the bumper and the rad support panel
Remove under tray (it screws to the bumper and the crossmember)
Undo the screws each side at the top corner of the bumper into the guard (very top corner of the bumper in the wheel arch)
Remove your front indicators and remove the 'spring bolts' from each side
Remove the 2 big nuts from each side of the front of the car
Disconnect the wiring and away you go!!
Old Holdens never die,they die WAY before they get old!
Posted: Fri Nov 26, 2004 4:52 pm
Ride: EF Falcon 95
thanks fellas,
if i have any dramas ill got with the pictures but for the moment i reckon ill be right, gotta wait for my new indicators to arrive anyhow. thats why im takin it off, replacin headlights and indicators with nice new clear ones, not yellow ones!
Posted: Fri Nov 26, 2004 5:53 pm
Ride: EF GliXR
with removing the spring bolts, you might need a 10" extension for your ratchet to reach thru under the guard.
\m/
Posted: Fri Nov 26, 2004 6:19 pm
Ride: EF Falcon 95
i got the bottom bolt out of the headlight with a normal ratchet! took a while, alot of swearing, a few ciggerettes and beers, but i got there. only to relise im gonna need the front bar off to pull the lights out :evil:
It is currently Sun May 18, 2025 10:50 pm All times are UTC + 11 hours
