1966 Xr Falcon |
Age: 46 Posts: 98 Joined: 27th Sep 2009 Ride: eb xr8 falcon/1966 xr fairmont Location: Elizabeth Grove |
Hi I just recently bought an XG XR6 from a mate and the blinkers are flashing like they are about explode, I have done the following cleaned all wire conections and bulb conections and changed flasher relay as well as added another earth cable to the front blinkers and still the blinkers are flashing off tap would this be a wiring problem or the indicator stalk, the hazards are flashing as normal.
ED_XR6_5 SPEED |
check you havn't blown a globe, i think the little ones on the guards can cause this aswell, can check if you like?
cheers, Tomo
_________________ 98%of city drivers will say ''holly s**t'' befor going into a ditch in a snowstorm and 98%of country drivers will say ''hold my beer and watch this'' |
LTDHO |
Horses where blinkers.
Cars have indicators! Sounds like a bulb is out. Does it work in one direction only? Does it also happen when the hazzards are on? |
1966 Xr Falcon |
All the blinkers are working left and right, and when the hazard lights are on they flash at a normal rate, if the globes are flashing it can't be a bulb, only thing i can put it down to is a dodgy wire or the indicator switch
1966 Xr Falcon |
ok just replace all the globes again, cleaned all earths and conectors still the same, when the hazards are on it flashes at its normal rate, when indicators are on they flash off tap right slighty faster than the left has anyone got any ideas
ea_silver_ghia |
Age: 41 Posts: 157 Joined: 21st Jul 2005 Ride: EAII Ghia & AUII Fairmont Location: South Oakleigh |
Does it have a towbar? If so check the connections on the towbar plug. I find sometimes my indicators start going mental, I simply have to push the cover on the plug in a bit better and it returns to normal
_________________ 1990 EAII Fairmont Ghia |
1966 Xr Falcon |
oh yea thats another thing when i conect a trailer the lights flash normal, so would that be an earth problem
1966 Xr Falcon |
found the problem the front indicators were put into the bumber for some reason and with the wrong wattage globes so i changed them back to standard
