FS: Leather XR steering wheel
Page 1 of 3 [ 32 posts ] Go to page 1, 2, 3  Next
 Post subject: FS: Leather XR steering wheel
Posted: Wed Nov 17, 2004 6:42 am
Gallery: 14 images
Ride: NF Fairlane [BLUBEL]
In great knick. Paid $150 from Mick Webb around 4 months ago.
Will be happy with around $80 + postage.
Posted: Wed Nov 17, 2004 7:36 am
Ride: EF Falcon
im interested, pm sent
Posted: Wed Nov 17, 2004 3:43 pm
Ride: '95 EF's
me too! let me know how much interest you get amber - i wouldn't mind as mine is f**k up...
R.I.P. Scotty
Posted: Wed Nov 17, 2004 3:57 pm
Gallery: 33 images
Ride: EL Fairmont Ghia
hmm did i see this goin for bugger all on ebay the other day :)
Posted: Wed Nov 17, 2004 4:05 pm
Gallery: 14 images
You did rapier, but the guy emailed me and told me it was too much for him!! :evil:
Wheel is now gone!!
Posted: Wed Nov 17, 2004 11:20 pm
Ride: BA XR8, XD Fairmont Ghia
i have some new ones for sale if anyones interested have them for sale on the counter for $150 say you from FM i will do them for $120
i have 10 only at this price . they are dark grey(almost black) leather
and i will freight anywhere in OZ for $15
Posted: Thu Nov 18, 2004 7:02 am
Gallery: 14 images
WOW! Thats an awesome price for new ones!! :lol: (considering I paid that for a second hand one)
FYI - i sent one off yesterday, and in a tough bag, registered and insured, it came to $15 :)
Posted: Thu Nov 18, 2004 1:50 pm
Gallery: 14 images
Ride: BA XR6 Turbo
Power: 175 rwkw
Mine sent off too Amber ?
I bought some black vinyl spray yesterday to spray my centre pad to match :)
Now if I can just replace the wheel without my airbag going off I'll be set! lol
Posted: Thu Nov 18, 2004 1:59 pm
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
You'll have no problem at all. I beleive its almost impossible to set them off while removing/installing them, though I still point them away from me when I carry them :P
Posted: Thu Nov 18, 2004 4:10 pm
Gallery: 14 images
Yup, yours is in the mail, cant be too far!!
Posted: Fri Nov 19, 2004 8:01 am
Ride: EF Falcon
is it hard to change the steering wheels over? anything specific that should/shouldnt do?
Posted: Fri Nov 19, 2004 10:40 am
Ride: BF Typhoon
All you need is: battery disconnected, wait 2 min at least, pop two small covers off the back of the airbag cover at the sides near the indicator stalks.
Undo the two bolts in you will see after removing the covers and then lift air bag "pack" and unplug it.
Then pull horn pads out, unscrew cruise control screws and other screws holding backing onto the wheel.
Use large torx bit to undo center main screw/bolt, bit tough at 1st if this is your 1st time dont remove bolt completely leave it so its JUSt still threaded in so when you pull wheel off it doesnt hit you in the face.
Then wiggle the steering wheel side, ie: hold at 9 and 3 o'clock and wiggle it till a bit loose, then 12 and 6 o'clock and repeat to wheel is off.
The wheel should stop coz you left the center tox bolt in a little and not hit you, once its loose just remove the center torx bolt completely and walah!
To put wheel on is same procedure but reversed, just make sure the wheel is TIGHTLY on the columb, i suggest a small mallet to hit the cente part of the wheel over the knob it sits on, very easy and works great!
Hope that helps someone.
BF Typhoon, Dejavu - 6sp Auto, Leather, Sunroof, 19"s, Electric Pedals, Tint, FPV Sports Wheel, FPV Mats.
Posted: Fri Nov 19, 2004 10:54 am
Ride: BF Typhoon
PS, dont OVER tighten your cruise control screws when putting them back on - ive heard that these break easily!
Ive changed wheels about 8 times or more now (dont ask) and havnt had this or any other problem as of yet.
Posted: Fri Nov 19, 2004 12:01 pm
Gallery: 14 images
Ride: BA XR6 Turbo
Power: 175 rwkw
Do you have to actually disconnect the battery ? Can't you just remove the airbag fuse? I guess it's better to be on the safe side rather than have it go off in my face!
Yes, I'm probably a bit over paranoid about them going off but if you knew the luck I seem to have around cars... :)
Posted: Fri Nov 19, 2004 12:09 pm
Ride: BF Typhoon
Put it this way, its litterly safer to play it safe when toying around with airbags.. id rather be sure than sorry.
You could remove the fuse, but what happens if for some reason someone removes the wrong one or just forgets or something.. just d/c the battery n play it safe IMHO. :wink:
Also AU use torx screws thru the whole unit apparently, whereas ef/el use normal screws with one large (T50?) torx screw.
It is currently Wed Jun 25, 2025 6:50 am All times are UTC + 11 hours
