dang |
Hi,
I'm looking to put a variable wiper switch in my EL GLi, and need to get a Futura BCM. The cheapest I've found from a wrecker is $145. Surely I can do better than that? Cheers, Dang. Last edited by dang on Fri Dec 03, 2004 8:18 pm, edited 1 time in total. |
Happy |
{USERNAME} wrote: Hi,
I'm looking to put a variable wiper switch in my EL GLi, and need to get a Futura BCM. The cheapest I've found from a wrecker is $145. Surely I can do better than that? Cheers, Dang. Good mod, that is exactly what I did in my GLi (and the mid series dash at the same time). Payed $60 for my BCM if it helps for a price guide.
twirqurky |
BCM?
dang |
Sorry, that's Body Control Module - the thing that controls all the boring stuff like lights, wipers and some other stuff I can't think of right now. There's some stuff in the Fordmods doc section on what it all does.
Hey Happy, was that a wrecker that charged you $60, or did you find someone wrecking one? Yes, I put a cop cluster in mine as well. Where did you get your pressure sender? I bought one from Ford and got them to put it in while they were doing an oil change. They charged me 45 minutes labour, with the sender it set me back $110.... oops. Cheers, Dang. |
altedxr6 |
I've got a fairmont one here, green, $50 if you would like it .
red rocket |
Hi should be able to get ya one for $50 plus postage give me a day to confirm that,
do you need the stalk arms as well? jase..
_________________ Johnny the boy has done it again, this time it was a scrubber.. |
xr8 dismantler |
{USERNAME} wrote: Sorry, that's Body Control Module - the thing that controls all the boring stuff like lights, wipers and some other stuff I can't think of right now. There's some stuff in the Fordmods doc section on what it all does.
Hey Happy, was that a wrecker that charged you $60, or did you find someone wrecking one? Yes, I put a cop cluster in mine as well. Where did you get your pressure sender? I bought one from Ford and got them to put it in while they were doing an oil change. They charged me 45 minutes labour, with the sender it set me back $110.... oops. Cheers, Dang. B.C.M is a holden term for their body control module. ford calls it a B.E.M a body electronics module. |
Happy |
Hey Happy, was that a wrecker that charged you $60, or did you find someone wrecking one? Yes, I put a cop cluster in mine as well. Where did you get your pressure sender? I bought one from Ford and got them to put it in while they were doing an oil change. They charged me 45 minutes labour, with the sender it set me back $110.... oops. Cheers, Dang. old FM1 member Scotts840 sorted me out with it, haven't seen him online since we came back up though. And I put in my sender myself. Went out and picked up the deep socket to fit it which made it easy. less than $20 for both the sender and socket!!
