ACT - EF Steering parts - Anyone wrecking an EF?
Page 1 of 1 [ 8 posts ]
 Post subject: ACT - EF Steering parts - Anyone wrecking an EF?
Posted: Thu Jan 04, 2007 2:26 pm
Ride: 2007
I am after an EF intermediate shaft that runs from the rack to the column.
Must be from an EF.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Thu Jan 04, 2007 6:37 pm
I'm wrecking an EL, assuming that this particular item is the same EF - EL?
Posted: Thu Jan 04, 2007 6:50 pm
Ride: 2007
You would think so wouldnt you, but no EF is unique. EL has a longer pinion so the shaft is smaller to suit. EA-ED have a course spline on the pinion where EF and EL are fine. However I now have one from a wrecker its damaged but should be OK for the EA.
,======o00o
Posted: Thu Jan 04, 2007 7:25 pm
Ha ha, you've gotta love all the running changes that are made don't you!
Posted: Fri Jan 05, 2007 9:48 pm
Ride: BOXCAR
I got an EF intermediate shaft :)
^^^ What He Said
Posted: Fri Jan 05, 2007 10:03 pm
Ride: 2007
Does it have the uni joint at both ends? If so how much are you after?
,======o00o
Posted: Fri Jan 05, 2007 10:10 pm
Ride: BOXCAR
its got a uni joint at the end that fits to the rack.
why would it have two uni joints? Its definatly from a EF because i saw the car it came from
the end that connects to the colum has a fine spline on it :?
Posted: Sun Jan 14, 2007 10:53 am
Ride: 2007
Pulled the shaft off yesterday and the top uni is part of the column not the intermediate shaft. Turns out the rack is OK and recently serviced going by the oil. The play in the steering was the rack bolts being loose and play in both uni's. Out came the steering column and a quick tighten on the uni's and all is good now...
,======o00o
It is currently Sun Jul 13, 2025 10:03 am All times are UTC + 11 hours
