WTD WA Rear Housing T5 Gearbox
Page 1 of 1 [ 6 posts ]
 Post subject: WTD WA Rear Housing T5 Gearbox
Posted: Sat May 19, 2007 9:53 am
Gallery: 5 images
Ride: 1994 ED Ricer
Have a huge crack in ours and its leaking fluid. I need a rear housing to suit an ED T5 v8 box.. Im not sure if the 6cyl t5 rear housing fits?
Posted: Sat May 19, 2007 2:54 pm
Ride: 96 XH/97 EL
AFAIK they should fit.
I suppose depending where the crack is, can you remove it and get it mig welded ???
I do have a rear extn housing off an EA 6 cyl, so if you need it - postage might be a killer, so investigate the 'easier' options first.
Good luck.
Posted: Sun May 20, 2007 10:52 am
Gallery: 5 images
Ride: 1994 ED Ricer
ok thanks mate i might get back to you on that one! cheers
Posted: Sun May 20, 2007 11:46 am
Ride: 96 XH/97 EL
NP.
Posted: Mon May 21, 2007 3:18 pm
Yep i can get you one!
Sourced one for a friend (for a BA xr6 box which doesn't have a speedo hole) turned out the BA box is longer and the stock T5 extension didn't fit.
Call my friend Shaun 0403221661 and explain that you are after the T5 extension. Call him after 6pm.
EA SVO Fairmont Ghia - Recaros, Bilsteins, Sunroof, SVO rims and body kit, Genie headers, DBA rotors. T5 steeda triax short shifter. 3.27 lsd. (EL 4.0 ported/polished, rebuilt and balanced, Dev5 cam. J3 chipped EL ecu, AU injectors).
Posted: Sat May 26, 2007 12:18 pm
Gallery: 5 images
Ride: 1994 ED Ricer
ford wanted 700 bucks for a new one so how much do you want for yours? Ill have to find out about postage too.
It is currently Wed May 28, 2025 10:01 am All times are UTC + 11 hours
