EF_nut |
I've got a 1972 Mach1 with the factory 351ci in it.
When I go to start it (from cold) it will crank fine but won't fire. This goes on for a few tries and then it will feel like it's going to catch but won't. Then it will catch briefly, then catch and run for a few seconds before dying. A few more tries later and it will run. This process will usually take around 5-10min depending on how long the cars been sitting. It will even happen if I drive the car in the morning and then leave it all day, but not as bad. It's got a mild aftermarket Roller Cam, good battery & starter motor. |
sooty72 |
Does it not have a choke?
_________________ Yes, I own a Ute. No, I won't help you move! |
Vic |
I'm gonna say timing might be off.
89.SVO |
Age: 35 Posts: 3382 Joined: 11th Mar 2008 Ride: EA SVO, AU2, Toyota Crown Location: Bendigo |
electronic or points ignition?
_________________ Daily driver: 2010 Toyota Crown hybrid 3.5L V6 hybrid. 254kw. |
EF_nut |
It doesn't have a choke and it's got Electronic Ignition.
