spark plugs
 Post subject: spark plugs
Posted: Tue Mar 15, 2011 10:22 pm
Ride: ebxr8
what would be the best plugs for the old girl? specs in my sig. eb xr8
347, crane cam, Pro topline 180 heads, Edelbrock victor efi intake, 80mm C&L maf, 75mm tb, 30lb injectors and 1/4 horse
 Post subject: Re: spark plugs
Posted: Wed Mar 16, 2011 6:41 pm
Ride: Lots, all Fords
I run NGK iridium spark plugs gapped to 1.00mm. Checked them after 3000k's and absolutely no fouling whatsoever. Engine pulls cleanly through the rev range, idle is smooth as well.
I chose them due to the extended lifespan and the reduced need to remove & clean them. I am happy with their performance.
Posted: Wed Mar 16, 2011 10:20 pm
Gallery: 5 images
Ride: 2021 Amarok V6
you can use NGK BPR5FS-15, Bosch HR9BPY, HR9BCY+, 2 sets of Bosch F9-4 (expensive!!), or Motorcraft T16PRU15.
Users browsing this forum: No registered users and 28 guests
It is currently Mon May 19, 2025 11:28 am All times are UTC + 11 hours
