Cam Positioning Sensor Drive
Page 1 of 1 [ 11 posts ]
 Post subject: Cam Positioning Sensor Drive
Posted: Tue May 10, 2011 8:29 pm
Can anyone inform me of where i can get a cam positioning sensor for my AU1 XR8 5 Litre.
The sensor part is all right it is the drive that goes into the motor that is worn and making quite a bit of noise. Went to ford and $960.00 for the part. If any one can point me in the right direction would be greatly appreciated.
 Post subject: Re: Cam Positioning Sensor Drive
Posted: Tue May 10, 2011 9:59 pm
Ride: au1 V8 1 tonne poverty pac ute
Hi, had a problem with mine a couple of years ago went to ford and was told about the same price, mine would start making a horrible noise and would start breaking down, the bloke at ford told me to try this, take the sensor off and tip a bit of oil into the top of drive still in the motor, did so and hey presto, fixed never had the problem again, hope this is of some help, cheers
Don't force it, use a Bigger hammer
Last edited by gotta luv a v8 on Wed May 11, 2011 12:40 am, edited 1 time in total.
Posted: Tue May 10, 2011 10:25 pm
Ride: 1993 EB XR8
It is actually a Camshaft SychroniserIt can be sourced here: http://www.rockauto.com/catalog/x,carco ... type,10722 for $36.
Posted: Tue May 10, 2011 11:16 pm
Ride: XG ute, XT sedan
Sorry miss read OP.
Posted: Tue May 10, 2011 11:54 pm
Hi, you will find that the camshaft synchroniser for the explorer 1996-1998 is not the same as a au1 5.0l, the one from the explorer motor from 1999-2001 is the same, I have the synchroniser tools for both to set the base timing, bought the wrong one first before i realized, gotem both from the U.S, still try the oil thing first, I only done it once and lasted for 2 years then I changed motors,(needed the tool to install new cam synch in new motor) otherwise you will find it at .http://www.rockauto.com/catalog/x,carco ... type,10722
Posted: Wed May 11, 2011 11:15 am
Ride: AU2 XR8
I have the Motorcraft type brand new that will suit. Still in box. comes with tool aswell.
yours for $70 plus postage.
They are normally around $100 in the US, then allow for freight - $40. The Motorcraft are the better brand, and are actually the Ford brand. Dorman are cheap chinese rubbish. I bought one and had it replaced as it didn't come with the gear wheel??
Posted: Wed May 11, 2011 7:26 pm
Thanks to everyone who has replied, has helped me out and greatly appreciated. Thanks again..
Posted: Wed May 11, 2011 7:32 pm
Hi, just wonderin if you were able to fix it or replace it, cheers
Posted: Wed May 11, 2011 7:54 pm
Going to order the part through the link you gave me. Just going to leave the old girl parked in the shed till the part arrives.. Luckily i have another xr8 to get round in.. The one that is playing up the AU has only 171000km on the clock.
Posted: Wed May 11, 2011 8:43 pm
Ok, thanks, while you have it sitting there , if you havent done so before you should give the MAF wires a clean won't help with the cam synchroniser but can make a fair difference with how the motor runs, there are a couple of threads on this forum about it, cheers
Posted: Thu May 12, 2011 4:03 pm
Ride: FG MK2 XR6T
I have the Dorman in mine which is working fine, but if I had my time again I would definetely pay the little extra and get the genuine motorcraft one as I have read a few bad stories from guys in the US.
Now......
Feb 2012 FG MK2 XR6 Turbo
- Manual
- Luxury Pack
Users browsing this forum: Google [Bot] and 6 guests
It is currently Thu Jun 19, 2025 10:25 pm All times are UTC + 11 hours
