is 22l per 100 ks normal
 Post subject: is 22l per 100 ks normal
Posted: Tue May 10, 2011 10:24 pm
Gallery: 9 images
Ride: 02 xls ute 347
hey guys ive got all the mods listed in my blog or what ever its called
ive just servised the car and im still getting 22l per 100
what r people getting? i might try the other tune on my cappa flash
02 series 3 AU marline ute 5speed 347 stroker
 Post subject: Re: is 22l per 100 ks normal
Posted: Tue May 10, 2011 11:00 pm
EFI Guru
Gallery: 28 images
Nope 22L/100 is not good.
Some things I've noticed...
75mm t-body is too big and will cause a torque loss down low which will hurt your fuel ecomomy.
What is this larger MAF?
What size are the header primaries?
How do these 20" wheels compare to the stock rolling diameter?
Flash it back to stock and retest fuel economy.
Changed your HEGO's lately?
Posted: Wed May 11, 2011 11:35 am
Just for something to go off, my AU S1 5.0 Fairlane gets around 13.2l/100klms. I sit in traffic for about 10-15 mins per day and about the same again on the highway. So i suppose you could call that fairly average driving.
Thats with big mouth intake, full exhaust system on 19's.
I would personally suggest you check out your oxy sensors, because if they are stuffed it will through out your AFR's pretty bad.
I think i got 2 off ebay for about $40 delivered??? and only take about 5 mins to replace (need a 22mm spanner though).
99 AU Fairlane Ghia V8 Black Leather, 19" ANZ 5+5's with 245/35 rubber
Full sound system. Extractors, Dual 2.25" exhaust.
Lowered on Tickford XR8 springs and shocks!!
Posted: Wed May 11, 2011 3:11 pm
A lot of the standard windsor 8's will chew through 13 ~ 14+ L/100 for stop/start city driving. Get 'em on the highway and they can drop down to 8L/100. But 22L/100 is shocking!
I would look at the obvious culprits first such as your MAF & HEGO's.
But you also said "other tune" so is it perhaps a tuning issue?
5.6L of carbon footprint.
Posted: Wed May 11, 2011 4:41 pm
Ride: Lots, all Fords
Assuming it's not a right foot or mechanical problem. Return it to factory standard MAF & ecu, clean both MAF sensor hot-wires and see what economy you get. That will determin if your O2 sensors are the problem. Like others have said, you should get 8-10 L/100km on a highway cruise which is the driving condition where O2 sensors are most important.
If it's not the O2's, then the bigger MAF and/or tune is the likely culprit. Start by cleaning & re-fitting the bigger MAF and re-test the economy with the modified tune. Still no good, then run all diagnostic scans (KOER will pick up a failed MAF sensor, but not a dirty MAF or one that doesn't match the tune). If the MAF is OK and no other fault codes are generated, then it's likely the tune does not match the components.
Posted: Thu May 12, 2011 4:11 pm
Ride: FG MK2 XR6T
Firstly, reset your trip comp average kmph and drive your normal run for a week and see what you get.
I do 100% city driving and I get anywhere between 17 - 19l / 100km. Average speed according to trip is anywhere between 28 - 31kmph. Nothing wrong with my car as I get 9.2l/100km highway cruise.
22l is abit high but if your average speed is about 25kmph it's about right.
Now......
Feb 2012 FG MK2 XR6 Turbo
- Manual
- Luxury Pack
Posted: Thu May 12, 2011 4:26 pm
Gallery: 12 images
Ride: BA XT V8
must be somthin goin on here. i have a fairly heavy right foot :lol: but my trip thingo says 14.4 / 100ks.
Unless your foot is flat all the time. Haha.
BA XT V8. Ice Mint. 18" Speedys. XR6T LSD. Full Pacemaker twin 2 1/2inch Stainless Steel system. Custom CAI. Black XR interior with white trimming. Powerbond underdrive kit 25%.
13.65@102mph. 2800 hi-Stall.
230RWKW@5250 rpm. 625NM.
Posted: Thu May 12, 2011 6:24 pm
Gallery: 9 images
not to sure what type of maf it is it was al ready upgraded on the car
how do i clean the maf?
the 20''s are about an inch and a bit larger than the stock rolling diameter "u can defenately notice loss in take off"
the trip computer is out of a 6cyl fairmont could that have anything to do with it coz teh original one stuffed up?
the cappa flash tuner i have has 3 tunes atm factory p1 and p2, on p1 it doesnt smell as rich and defenatley doesnt have as much guts in it on on p2 tune it smells very rich but boots alot harder.
im thinking from running it rich maybe ive failed the spark plugs
im goin to get new spark plugs maybe leads clean the maf. can i clean the oxy sensors? and run it on the less harsh tune and see what i get
90% of my driving is in the city and for bugger all mainly to gym and back which is 2 k drive
p.s im sitting on 24.8 l/100 atm i boot it here and there but geeze this is F**k
Posted: Thu May 12, 2011 6:30 pm
Gallery: 9 images
sorry to sound dumb lol whats a HEGO?
Posted: Thu May 12, 2011 6:39 pm
HEGO = oxy sensors on each exhaust header.
Posted: Thu May 12, 2011 6:57 pm
Gallery: 20 images
Ride: ED Falcon
Power: 133 rwkw
Heated Exhaust Gas Oxygen sensor... Tells the computer the AFR of the exhaust gases... One of the sensors used to determine whether to squirt more or less juice into the cylinder...
Posted: Thu May 12, 2011 7:16 pm
Ride: Territory SX TX
Just out of stupid random curiosity, how many K's are you getting out of a tank without reffering to the trip computer... ie fill up and reset trip meter on dash... and also, what kind of driving are you doing??
Posted: Thu May 12, 2011 11:08 pm
Gallery: 9 images
im not to sure what ive goten out of a tank yet havnt tryed i think it was about 320? im not to sure.
im guessing with the bigger wheels its waked out my ks and trip computer abit give or take a few ls or ks
most my drivin is short trips and i warm up the car every time i go to drive it
Posted: Thu May 12, 2011 11:26 pm
ACT Cruise Moderator
Ride: '06 BF GT-P
Power: 293 rwkw
warming up is a waste of fuel and time, just don't go flogging it while still cold. The car will warm up much quicker with some normal driving, than it will idling away in cold start enrichment throwing fuel out the tail pipe.
Yes, if the wheel+tyre size is drastically different to stock, the odometer + speed + therefore the trip comp calculations will be out of whack.
Posted: Fri May 13, 2011 9:14 am
Power: 482 rwkw
Try the BASICs..
Check thermostat and coolant temp sensor...
Leads and plugs...
Any leaks around front exhaust can throw out 02 sensors also..
As in ZOOM 126 edition
It is currently Sun May 18, 2025 2:48 am All times are UTC + 11 hours
