retarding timing at startup
 Post subject: retarding timing at startup
Posted: Mon Jun 13, 2005 10:33 am
Gallery: 5 images
Ride: NC fairlane + f150 4X4
g'day cobbers
just after some thoughts on retarding timing (just at startup) on an old windsor. the dizzy is curved for gas which means alot of initial timing plus advance comes in earlier. this is putting way to much stress on the starter. so far i've killed 2.
was thinking one of those nitrous retardin boxes it it could be hooked up to work when the starter was turning. any ideas would be greatly appreciated.
If mistakes are the best way to learn why the hell arn't I a freekin genius yet.
I AM THE SPELLING KING BEHOLD MY
ineqati-inekwati-enequoati.....crapness!
Posted: Mon Jun 13, 2005 10:57 am
did u not already post something like this a while back?
if it has killed 2 starters what ones are u using? and have u tried a high tourque unit?
RIP SCOTT
Posted: Mon Jun 13, 2005 11:18 am
Gallery: 5 images
yeah I had a staba in the ecu and fule system forum but it doesn't have an ecu and It didn't get much feedback. figured there are more oldschool people hangin out in this neck of the woods. plus I was fairly aggitated when I wrote the old post and on reading it back it was a touch incohearent.
I have only used the old style clapper starter and next payday will be dropping a gear reduction unit in there. however I figure if I can reduce the stress on the new starter it'll live a much longer life as well as the battery.
Posted: Tue Jun 14, 2005 2:26 am
mmm
umm what about a recurve of the dizzy to give low advance at real low rpm ie below idle speed and then at idle speed the advance kicks in??
but then again i am not sure the engine will fire on lpg with such a low advance...
have u thought about uprading the ignition system?? i be 9mm leads and a bigger coil with a twin point dizzy? or even converting to electronic ignition
RIP SCOTT
It is currently Fri Jun 06, 2025 1:08 pm All times are UTC + 11 hours
