wassa78 |
im now an owner of a 2001 au xr8 220kw 5speed man its all stock just the way i like it but i must say after just selling a 2005 fpv i may need just a little more power so just thought i would ask you all out there what would be some of the mods power wise for under 5g you would all do i will say i love the sound of the au xr8s with a big cam but dont realy no much about them or how it would afect the way it drives and it reliability or its resale down the line
XFWAGON |
Turbo
WindeX |
Mate I think you'd be hard pressed to go past a Raptor supercharger kit. Comes in under 5k. They are a sponsor of this site but here is a link to their page.
http://www.raptorsc.com.au/kits.php?id=53 |
EBXR8380 |
YEP forced induction takes some beating..
Any first mod should start with exhaust.. Then anything done latter enhances the whole package...
xafalcon |
The T5 is a potential problem, depending how you drive it. And the raised compression in a 220kW engine together with hypereutetic pistons makes forced induction more expensive. Might be worth considering starting with a clean slate, spending a bit more up front and selling the current drivetrain after you swap it. Maybe look at a crate stroker, based on either an 8.2" or (preferably if your laws allow it) a 9.5" deck block. Remember a good chip & tune will cost about $1k no matter what you do to the engine
_________________ XA Faimont 351C, AU2 XR8 Manual 5.0, DA LTD 5.0, Mk1 Capri 5.0, 1995 Mustang 5.0, EF2 XR8 Manual, EF2 Fairmont Ghia 5.0, AU3 XR8 Auto, AU2 XR8 Auto, AU2 XR8 Manual Ute, TE Cortina 5.0 Manual, DU LTD 5.0 soon to be manual |
TKFD |
gotta, just gotta do the basics first before S/C - let the engine BREATHE
exhaust - $2000 (get rid of those s**t std headers go Tri-Y) Hi Flow K&N filter - $100 Intake manifold spacer - $75 Port match/port Intake manifold - $500 Tune - $1000 could then clean up heads - $1000 that should get you about another 50rwkw |
xhxrsix |
Another 50kw is a bit much isn't it?
std AU header aren't as bad as the older models but it all helps i guess. Depends what your after but a supercharger would be the easiest way to go if you want a decent increase...
_________________ EF V8T 11.54 @118mph |
