el xr8 running rough in the hot conditions
Page 1 of 1 [ 15 posts ]
 Post subject: el xr8 running rough in the hot conditions
Posted: Wed Nov 09, 2011 10:55 am
Ride: el xr8, mk1 escort
Hey guys just wondering if others have experienced similar problems before
Car is el xr8 s1, manual
mods, gt40p, y/t rockers from an au, au220 cam, explorer manifold, 65mm tb and au 70m maf, also has a j3 chip, hurricane headers
car has been running good since early September when i did the mods but last Friday problems started
it was a hot day in Sydney and big traffic as it took about 50mins to go 10km, then once we had open road i go to give it a hit and the car would struggle to move, jerk around and backfire, i limped it home
it was fine over the weekend
yesterday leaving work again, as soon as i pulled out, it would jerk, back fire, knock, struggle to rev over 2000rpm, would stall and the idle would jump all over the shop
got home ripped the j3 chip out, and the car went better
then again this morning driving to work, it was fine until the heat soaked the engine, when i got on the juice pedal it felt like a dog, and was begging me not to rev it out
the car is driveable with slight throttle but when you open it up it has nothing (but sound, still sounds good :P), i am thinking along the lines of coil/dizzy / or dizzy cap and rotor button
any ideas, and tips are welcome
thanks
Andy
 Post subject: Re: el xr8 running rough in the hot conditions
Posted: Wed Nov 09, 2011 3:26 pm
Ride: Lots, all Fords
TFI module most likely.
Does the chip have the correct mass transfer function for the AU MAF? And the right slopes for the blue AU injectors?
Posted: Wed Nov 09, 2011 3:45 pm
yea gave a list of mods for the chip, i am using standard el injectors though
also was just mucking around with the car on my lunch break at work, noticed the coil tip was hammered so i ordered a new coil and will pick it up after work
Posted: Wed Nov 09, 2011 4:48 pm
19lb injectors are insufficient
Posted: Wed Nov 09, 2011 7:55 pm
EFI Guru
Gallery: 28 images
Could also be your fuel pump or your MAF.
Posted: Wed Nov 09, 2011 8:39 pm
Changed the coil, also took off the dizzy cap and it was full of dust/shavings and there is lots of play in the shaft, ordering a new distributor tomorrow, wiped the dizzy cap and the car seems to go better
Posted: Thu Nov 10, 2011 8:12 pm
Changed the dizzy today and cleaned the Maf and it worked wonders, car is back to normal
Posted: Sat Nov 12, 2011 2:09 am
Ride: EL XR8, '08 Mondeo XR5t
Power: 205 rwkw
Have you run the car on the dyno with that combo and the J3 chip, to check the AFRs?
Posted: Sat Nov 12, 2011 8:28 am
Scaffy, I left the j3 chip out for now
I do want to run it on the dyno with and without the chip to check out the afr and see if the chip needs to be retuned, or just find a workshop in Sydney who tune the j3
Posted: Sat Nov 12, 2011 7:58 pm
Power: 482 rwkw
Thermostat and purge relay can cause issues also...
If engine doesn't get up to temp it will run rich..
If purge relay doesn't work ?? It lets hydrocarbons through engine
and 02 sensors try to lean it out, engine loses power...
Inlet and coolant temp sensors can cause similar issues...
As in ZOOM 126 edition
Posted: Tue Nov 15, 2011 6:51 pm
Ride: EF Ghia 5.0
Where is the purge senior relay? I've been having similar issues for years! It had a fault code for the purge senior, so I swapped it for another,but no joy. I assumed it wasn't the problem and forgot about it.
Thanks, Mike
EF Ghia 5.0 - XR8 in a tuxedo....classy, low and loud
Bordeaux Purple, Tickford kit, slammed, 18" BA XR8's, EL Ghia chrome, full leather, Pioneer audio, C&C, ABS, LSD, Crane cam, GT40P heads, high flow cats, Genie extractors, lots of woodgrain, chrome and interior lights!
Posted: Tue Nov 15, 2011 6:52 pm
Ride: EF Ghia 5.0
Where is the purge solenoid relay? I've been having similar issues for years! Ithad a fault code for the purge solenoid, so I swapped it for another,but no joy. I assumed it wasn't the problem and forgot about it.
Thanks, Mike
Posted: Wed Nov 16, 2011 5:25 pm
Purge solenoid is up front under the left guard by the ABS pump. Follow the vacuum line that runs forward from underneath the upper intake manifold.
Posted: Wed Nov 16, 2011 6:15 pm
Ride: EF Ghia 5.0
Thanks mate, but I have replaced it before. I'm wondering if it's controlled by a relay somewhere that is playing up?
Posted: Wed Nov 16, 2011 8:10 pm
Controlled directly by the ecu
It is currently Mon May 19, 2025 10:57 pm All times are UTC + 11 hours
