AU V8 TPS Wiring
Page 1 of 1 [ 1 post ]
 Post subject: AU V8 TPS Wiring
Posted: Sun Jan 29, 2012 5:25 am
Gallery: 12 images
Ride: DCII LTD V8
OK, so I bought a new BBK tps (e-series style) to fit my au t/b, started to elongate the holes like I did with my first t/b swap (not quite as extreme though), but the bbk item is not as well built as the factory ford tps. The plastic is brittle and looks like a bar of aero chocolate, so that broke into many pieces.
I now have a 3 pin au tps that I plan to wire to the e series plug. I've browsed some Mustang forums and found the wire colours, but I just need to know which pin is what wire (abc pins).
Cheers.
Trick Flow Heads/Cam/Intake, Crane Ignition, T5Z Trans.
Users browsing this forum: No registered users and 28 guests
cron
It is currently Tue May 20, 2025 9:16 am All times are UTC + 11 hours
