mendyxr6 |
Is swapping the 302w from my Au xr8 to my Ef Xr8 as easy as I think it is in my head.
My heads saying Pull motor and trans from both cars. Remove looms ecu and wiring and swap them over or graft them into the existing wiring Hook it back up and drive away Any thing else I've probably not considered?
_________________ kangaroos and radiators are a bad mixture |
Johnson stroker |
you will need to retain the EF dizzy. But, yeah, thats about it.. You may also want to look at the AIT position, the E series has it in the lower manifold, AU has it in the Intake pipe pre manifold.
WARMACHINE |
Yh if you swap just the motor the ef will need the dizzy, your ef ecu should run it.
mendyxr6 |
Then I have to get the ecu chipped as the au is manual and I want to bang the hole thing across.
Pedal box will suck balls but
Matt_jew |
Pedal box is the easiest bit. Mal Wood pin.
mendyxr6 |
That's a lot easier then removing the Au one and fitting it into the Ef
XR9UTE |
Depends how you want to do it?
The easiest way? Or the best way? |
Gab1 |
{USERNAME} wrote: That's a lot easier then removing the Au one and fitting it into the Ef It's alot easier than removing the AU one and fitting it to the EF, because that WONT BE HAPPENING. Gab |
