windsor manifold spacer and egr spacer
 Post subject: windsor manifold spacer and egr spacer
Posted: Tue May 15, 2012 10:53 pm
Gallery: 9 images
Ride: 02 xls ute 347
hey guys is this the rite EGR spacer to go onto my explorer manifold on my au i already have the 75 mm elderbrock throttle body
http://www.ebay.com.au/itm/Professional ... 2c64f2e24d
also what are peoples thoughts on the manifold spacer i heard u get a little bit of gain and your also able to then fit after market rocker covers heres one i found on ebay will it fit?
http://www.ebay.com.au/itm/FORD-MUSTANG ... 20c4e5683c
02 series 3 AU marline ute 5speed 347 stroker
 Post subject: Re: windsor manifold spacer and egr spacer
Posted: Wed May 16, 2012 9:38 pm
Power: 274 rwkw
Both of those will work fine, but you will need to fab up a bracket to mount your accelerator cable. The Phenolic spacer allows you to run taller rocker covers, plus it helps with heat soak to the manifold upper, and theoretically allows a cooler charge to enter the engine.
Brett
Member#1131
Posted: Thu May 17, 2012 10:08 am
EFI Guru
Gallery: 28 images
A 75mm t-body is too big. You need to drop back to a 70 max.
Posted: Sun May 20, 2012 10:12 pm
Gallery: 9 images
Ok sweet :) the egr I notices had breathers on it what the he'll r they for should I jut bock them up ? I thought 75 mm throttle body is to small for my pretty hot 347 stroker I put it on coz I had it from my last car but ideal though 9mm would b the go to Mach the bigger maf sensor.. So I gotta make up a bracket for the acc cable because the top manifold will b to high ?
Posted: Mon May 21, 2012 1:48 am
Ride: au1 V8 1 tonne poverty pac ute
You need to make a bracket because the accelerator cable bracket that bolts onto the standard egr will not bolt straight onto the after market egr, the "breathers" have no effect on the air intake and do not need to be blocked off and can be left or cut off or as I have fit a hose that runs from one side to the other going underneath the egr just to look neater. If there is a hole that goes through the side of the egr body you will need to block that off.
Don't force it, use a Bigger hammer
Last edited by gotta luv a v8 on Mon May 21, 2012 6:24 pm, edited 1 time in total.
Posted: Mon May 21, 2012 3:09 am
Gallery: 40 images
Ride: EF GLi/Ghia bitsa
Sorry to Hijack this thread, but would that spacer still allow the manifold to clear the bonnet on an E Series?
Gab
Posted: Mon May 21, 2012 10:19 pm
Gallery: 9 images
ok sweet cheers guys im gonna order them then.. or is there any were in australia to get them ?
Posted: Wed May 23, 2012 12:36 pm
Ride: EF XR8
Gab
The TPS ontop of the throttle body is the highest point. I have a 1/2" phenolic spacer and it does not foul on my EF, but there is not much in it
Posted: Wed May 23, 2012 3:13 pm
EFI Guru
Gallery: 28 images
Gab
Manual or auto?
Posted: Sat May 26, 2012 7:41 pm
Gallery: 9 images
its a manual there are different parts codes for the same ones on ebay they have the exact description
Posted: Sat May 26, 2012 9:00 pm
EFI Guru
Gallery: 28 images
The point is, an auto has ganged throttle pots so, its' twice as high for an auto.
Posted: Fri Jun 01, 2012 11:15 am
Ride: EF XR8
Gab
Manual or auto?
Sorry, yeah mine is manual
Posted: Wed Jun 12, 2013 2:31 pm
Gallery: 9 images
Does any one know if a 2 inch spacer will fit under an au bonnet with out hitting when the engines under load ? And could I for those ford racing rocker cover is I use the one inch ?
Posted: Thu Jun 13, 2013 9:06 am
Ride: NL Fairlane Ghia V8
Very unlikely. I have a 1/2 inch spacer on my NL and the tps and front upper manifold bolt touch the underbonnet insulation. AU's may even have a little less clearance, depending on wether it's a low or high series bonnet. You would struggle with a 1 inch let alone a 2.
Posted: Thu Jun 13, 2013 10:19 am
Ride: BA XT, NCII V8
hey guys, older thread but these are some things im looking to do to my 302, i understand the spacer is also good for making the intake runners longer giving a little more torque, with the EGR, can i just get a EGR plate to delete it, as i think its a stupid idea?
It is currently Fri Jun 20, 2025 8:02 pm All times are UTC + 11 hours
