No oil pressure AU XR8
Page 1 of 1 [ 9 posts ]
 Post subject: No oil pressure AU XR8
Posted: Thu May 08, 2014 10:13 am
Ride: xp falcon, xt falcon, xh xr6
Power: 182 rwkw
Hi guys
I have an AU XR8 ute.
Started my car this morning and the oil light came on and noticed there was no oil
Pressure on the gauge. sounds like it may have a slight knock now.
Any answers to my this would have happen?
Oil pump? Pickup fell off?
 Post subject: Re: No oil pressure AU XR8
Posted: Thu May 08, 2014 3:32 pm
Ride: Fairmont AU I
Checked oil level?
Posted: Thu May 08, 2014 11:59 pm
check the oil level,
then get a mechanical pressure gauge on the engine to check
the au xr6's are shocking for a bad and incorrect oil pressure reading and they needed 1-2 extra earth leads from the -ve of the battery to the block behind the p/s pump, this fixed the incorrect gauge reading
no idea if the xr8's are the same though
RIP SCOTT
Posted: Fri May 09, 2014 4:44 pm
Ive blown two oil senders - that is, they start, read normal, then the oil leaks through and they go to 0.
Car is fine, but eventually Ive had good oil leaks from it.
Always worth a check
Posted: Fri May 09, 2014 6:07 pm
Ride: EF Fairmont
Only AU1 XR6's had an actual working gauge, Series 2 & 3 were just a swith and the gauge acted like an idiot light. Any acceptable Oil pressure = Gauge in the middle, No pressure = 0 reading on the gauge. Nothing in between.
Posted: Sat May 10, 2014 1:18 am
lol serious? interesting fact
RIP SCOTT
Posted: Sat May 10, 2014 7:41 am
Ride: EF Fairmont
Yes it is fact and I have seen it on all 2 & 3 series AU's. You also can't throw a series 1 dash into a series 2 -3 either.
Posted: Sat May 10, 2014 8:23 pm
well yer due to smart shield not smart lock
RIP SCOTT
Posted: Sun May 25, 2014 9:54 am
Ride: xd falcon territory turbo
did you get the oil pressure issue fixed. it sounds like my old au1 xr8 when at idle the oil pressure droped to nothing and it had a light bottom end knock but once u rev the engine it picked up. I replaced the main and big end bearings
It is currently Tue May 20, 2025 2:32 pm All times are UTC + 11 hours
