Au windsor into a ef
Page 1 of 1 [ 2 posts ]
 Post subject: Au windsor into a ef
Posted: Thu Aug 17, 2017 7:38 pm
Ride: ford
Hi
will a ef with a au 302 windsor need engineering as they also came out in a 302 windsor but au was about 170-175kw ef/el1 165-170kw el2 xr8 was 185kw but is same body as ef/el1
what makes el2 different for engine than ef/el1 even though they have same body
wondered because regency say upto 169kw, will it matter if the 302 was from a au with a few more kw as efs came in a 302 as well
what makes the el2 xr8 different from the ef/el1 with the engine, is the body and k frame same still same
Can you get a au v8 engine bay harness and take out the ecu wires and get a ef 6 cyl engine bay harness and take out the ecu wires replace them with the au v8 ecu wires keeping the abs and power and headlight wires from the ef harness and tape it all up again
Someone on fordmods has done that
Thanks so much for any help/answer
 Post subject: Re: Au windsor into a ef
Posted: Tue Aug 29, 2017 3:39 pm
EFI Guru
Gallery: 28 images
>No.
>Explorer intake, EL GT headers.
>No.
>The same.
>If you wanted to yes. I would adapt the AU harness and EEC into the EF...but that's just me.
It is currently Mon May 19, 2025 9:33 pm All times are UTC + 11 hours
